Scratches - specularity
Hiya, i've put texture of scratches on my car's body and set it in blendigo as bumpmap and exponent(in blender 'map to' options i've pressed nor and spec) but these scratches looks strange, because light doesn't penetrate them(they should've white color inside)
- rysy.JPG (239.05 KiB) Viewed 6678 times
Blender options are ignored for materials, so 'nor' and 'spec' aren't going to do anything for you.
In Blendigo, I would say you have 2 options available to you if you want your scratches to show depth and a different color.
1: Make a blended material. One of your car's paint color and one of 'Null'. with a grey, primer material underneath. Of course you'll need a mixmap. You could probably get away with using the same image for the Bump and the Mix.
2: UV map an image texture for the car with scratches and all, then add the bump map.
- joegiampaoli
Hmmm ... Maybe first, coul'd You make a region render of Your scratches and let it renders some time, one hour or two, in order to see more precisely what's happen ...
Second, maybe the bump heights values are inverted ?
You coul'd try to invert Your image in some 2D program' and make another test render ...
Have no other idea ...
