No material preview
No material preview
A user of maxigo seid me that the material preview don't work...
what is the problem?
filippo
sorry for my poor language
filippo
- error
- untitled.JPG (168.26 KiB) Viewed 14490 times
Hi, I can translate the phrase "impossibile eseguire il programma specificato" as " Impossible to execute the program specified"
that I think should be the console.exe
Hey,saxophone wrote:Hi, I can translate the phrase "impossibile eseguire il programma specificato" as " Impossible to execute the program specified"
See if you have the console.exe in that folder.
Also (as a general tip) use only "good" characters in material names. Indigo doesn't like foreign symbols and such.
Hi, the indigo_console.exe is in the mat_prev folder.suvakas wrote:If the .exe is there and it still doesn't work, then post the material_preview.igs file from the same folder. I'll take a look at it.
I've changed the 02_default material name in "teapot" but doesn't still work fine
I attach the material_preview.igs file
- material_preview.igs
- (17.43 KiB) Downloaded 384 times
Thanks Saxo !
I think I found the problem. Maxigo probably doesn't automatically copy the required dll's from indigo root folder to Mat_prev folder. These are needed for console.exe to start. See if you have the dll's and if not, then you can copy the dll's manually from Indigo's root to Mat_prev folder. Take all of them.
[edit]
Actually I don't have Maxigo here at work, so I'm not 100% sure if Maxigo copies the dll's or not? But check out if you have the dll's in the Mat_prev folder
[edit]
I don't have any .dll files in ...\indigo_v1.0.9_3\Exported_From_Max\Mat_Prev but preview works...
Also if i just unrar your folder and run the Batch file, I get no error or anything and this result:
(Logfile: http://pastebin.com/m2ab8ea0d )
- teapot__447792.png (21.42 KiB) Viewed 14258 times
