afecelis
by afecelis » Wed Apr 09, 2008 1:48 pm
Thanks Smartden!
The Linux GUI fix was exactly what I needed!!!!
Superb, terrific, fantastic work!!!
regards,
Alvaro
palawat
by palawat » Wed Apr 09, 2008 6:18 pm
Thank you, SmartDen.
It works on XP 32 with Blender 2.45. I plan to test it again this weekend.
Really appreciate your time.
Cheers,
SmartDen
by SmartDen » Wed Apr 09, 2008 11:26 pm
neepneep wrote:.sphere primitive doesn't work for me.
exporting object "Sphere.sphere"
material [Material "Phong"] found
File "<string>", line 3010, in buttonEvt
File "<string>", line 2325, in exportStill
File "<string>", line 2303, in export
File "<string>", line 2181, in exportIndigoScene
File "<string>", line 1713, in exportObjects
File "<string>", line 1638, in exportObject
File "<string>", line 1429, in getBoundingBox
TypeError: 'Blender MVert' object is unsubscriptable
fixed and uploaded
Check normals, dude!
Pinko5
by Pinko5 » Wed Apr 09, 2008 11:44 pm
Tnx Smart!!!
Luca.
SmartDen
by SmartDen » Thu Apr 10, 2008 5:24 am
in some way i can't get this damn preview scenes working
hope this time...
download from first page, if anybody need previews
joegiampaoli
by joegiampaoli » Thu Apr 10, 2008 6:24 am
Thx SmartDen!
Joe Giampaoli
My Indigo Gallery
JDA
by JDA » Thu Apr 10, 2008 8:13 am
Thx SmartDen
Cheers.
Pinko5
by Pinko5 » Thu Apr 10, 2008 8:17 am
Luca.
5OnIt
by 5OnIt » Thu Apr 10, 2008 9:09 am
*possible* bug - and I say "possible" because I'm not sure if you want Blendigo to behave this way or not.
When setting up a phong material, and you enter an NK data material, then you change you mind and change it to Specular Reflectivity, the nk data is remembered and over rides the Specular Reflectivity settings even though the NK data field is gone. You have to manually deselect the Speculal Reflectivity button, delete the entry in the NK data field, and then go reselect the Specular Reflectivity button.
Really not that big of a deal, just letting you know. Might end up biting someone if they hit render and walk away!
SmartDen
by SmartDen » Thu Apr 10, 2008 7:36 pm
5OnIt wrote:*possible* bug - and I say "possible" because I'm not sure if you want Blendigo to behave this way or not.
Thanx
Fixed and uploaded
pixelminer
by pixelminer » Sat Apr 12, 2008 5:53 am
I've been using the script to render some short animations and noticed the frame numbers the script spits out does not have leading zeros which means the rendered frames need to be renamed before I can load them in to some other program.
1,2...9,10 is no good.
0001,0002...0009,0010 is how it should be.
phong.
p.s. Yeah, rendering thousands of frames with Indigo is still a dream but it would be nice to be able to render say a hundred and not have to rename them afterwards...
Jacco
by Jacco » Sun Apr 13, 2008 12:46 am
I get this error
Thanks anyway
Join #indigo at irc.freenode.net
SmartDen
by SmartDen » Mon Apr 14, 2008 8:26 pm
Jacco wrote:I get this error
image skipped....
Thanks anyway
what versions do you use?
Hmm, strange... the curves should working. can oyu giv me an example scene.
palawat
by palawat » Tue Apr 15, 2008 12:05 am
SmartDen wrote:in some way i can't get this damn preview scenes working
hope this time...
It works great.
Thanks again, SmartDen.
Cheers,
by BbB » Wed Apr 16, 2008 2:24 am
Hi SmartD
Looks like bump maps are not getting exported when used with an Oren-Nayar mat.
EDIT: Also, any reason why the B value is capped at 10,000 in the exponent channel of the phong?
