Indigo v1.0.9 for Linux Build 2
afecelis
Post by afecelis » Fri Apr 11, 2008 6:11 am
Working great!
I'm using 64 bits version on Xubuntu64 7.10 (gutsy), GUI version launched via Blendigo. (dunno how to use the console version ;) ).
The only issue is still the log text appearing over the rendered image. Other than that, it's friggin' great to have native linux builds! :D
Thanks a lot Ono.
Regards,
Alvaro
delic
Post by delic » Fri Apr 11, 2008 7:11 am
Great news !
But cant make it work on ubuntu64 "gutsy" .
Console said this at the end of export from blendigo and blender2.45_x64 :
"/home/axis/indigo_x64_linux_v1.0.9_2/IndigoWrapper.sh" &
./indigo: error while loading shared libraries: libwx_gtk2u_aui-2.8.so.0: cannot open shared object file: No such file or directory
Did I miss something to install ? Was it installed wrong ?
I'm noob on linux ...
:oops:
zsouthboy
Post by zsouthboy » Fri Apr 11, 2008 8:11 am
delic:
I'm running gutsy x64 and have no problem with both console and GUI version of Indigo.
Are you completely up-to-date?
What happens if you run Indigo manually, without using Blendigo? (cd to the Indigo folder, ./indigo) - same thing?
Ono:
Thank you for the build, however, I'm currently investigating a seg fault that happened with my first render with this version.
Display took 0.21487 s
Time elapsed: 22 m, 6 s
Done 352030000.00000 samples (2346.86667 samples per pixel)
265437.41994 samples / second (3.76737 micro-seconds / sample)
Segmentation fault (core dumped)
.9 for linux has run flawlessly for me (in fact, this is my first adventure with 1.0+ because I haven't needed anything new) on this same box.
I'll investigate further and see what's going on.
zsouthboy
Post by zsouthboy » Fri Apr 11, 2008 9:05 am
Tried again, this time segfaulted in 40 mins.
I'm gonna try other scenes and see what happens; I also should try and see if the GUI version does the same thing..
Display took 0.24425 s
Time elapsed: 40 m, 13 s
Done 984880000.00000 samples (6565.86667 samples per pixel)
408026.16009 samples / second (2.45082 micro-seconds / sample)
Grimm
Post by Grimm » Fri Apr 11, 2008 10:06 am
Hi delic,
Sounds like you need to install the gtkwx libraries. On Fedora I just used yum to install them from the repository, not to sure if Ubuntu uses yum or not.
yum install wxGTK
delic wrote:Great news !
Grimm
Phr0stByte
Post by Phr0stByte » Fri Apr 11, 2008 1:51 pm
Working great here on Ubuntu "Hardy" (x64). Both console and gui are working great!
Ono:
Any particular reason for switching the gui to gtk? It is prettier, but harder to work with from a coding perspective - especially as xWindows is cross platform and will work with linux just as well... Just wondering
[EDIT] Ah missed the wxGTK part...
zsouthboy
Post by zsouthboy » Sat Apr 12, 2008 4:54 am
Wow, amazingly enough, Indigo crashes around the 40 minute mark every single time I've tried this render (6 times now). Bizarre (I'm sure it's coincidence).
I'm going to see if the 32-bit version does the same thing.
EDIT:
Indigo 32-bit:
Display took 0.26014 s
Time elapsed: 52 m, 12 s
Done 2934110000.00000 samples (19560.73333 samples per pixel)
936551.42330 samples / second (1.06775 micro-seconds / sample)
WTF!
I'll try the Windows version in Wine next. Dammit!
zsouthboy
Post by zsouthboy » Sat Apr 12, 2008 2:13 pm
Well this doesn't help me figure out the problem.
Indigo 32 Windows on the same box, in wine:
Display took 0.32467 s
Time elapsed: 7 h, 21 m, 36 s
Done 5124300000.00000 samples (34162.00000 samples per pixel)
193396.87809 samples / second (5.17071 micro-seconds / sample)
Grimm
Post by Grimm » Sat Apr 12, 2008 6:50 pm
My problem is just the opposite, Indigo under wine will only run at most 1.5 hours before it locks up. Indigo under Linux will runs with out a problem, the console version at least. Very strange, I have no clue as to what might be the common thread. ??
Grimm
leope
Post by leope » Sat Apr 12, 2008 9:14 pm
Thanks a lot Ono! It works great on opensuse 10.3 64bit.
With box emitter test:
Windows version + wine ~170.000 samples/sec
Linux native 64bit ~ 186.000 samples/sec.
(opteron 180, ddr 333)
delic
Post by delic » Sat Apr 12, 2008 10:29 pm
About 10% faster on the meshlight test file, with gutsy64 than Xp64 !
jurasek
Post by jurasek » Sat Apr 12, 2008 11:43 pm
Grimm wrote:My problem is just the opposite, Indigo under wine will only run at most 1.5 hours before it locks up. Indigo under Linux will runs with out a problem, the console version at least. Very strange, I have no clue as to what might be the common thread. ??
what wine version?
greetz,
jur
Grimm
Post by Grimm » Sun Apr 13, 2008 7:39 am
Hi Jur,
I am using 0.9.55-1 although I see an update to 0.9.58-1. I will try the new version and see if it makes any difference.
Grimm
Grimm
Post by Grimm » Sun Apr 13, 2008 8:54 am
Indigo under wine just locked up after a little more then an hour of render time. :( This is under version 0.9.58-1 of wine. This is usually not much of a problem for me as I just use Indigo under wine for my preview renders. When I need to do a final I just render it under the Linux version of Indigo_console. :)
Grimm
jurasek
Post by jurasek » Sun Apr 13, 2008 10:49 am
Grimm try 0.9.46.
greetz,
jur
