Indigo v1.0.9 for Linux Build 2
Changed parsing code to fix weird parsing error,
statically linking with OpenEXR
x64:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
32 bit:
x64:
32 bit:
Hi Ono,
I got the same error for the 64bit version as I did before:
The 32bit version has the same issue.
The console version works great. The distro I'm using is Fedora 8.indigo_x64_linux_v1.0.9_2]$ ./indigo
Fatal Error: Mismatch between the program and library build versions detected.
The library used 2.8 (no debug,Unicode,compiler with C++ ABI 1002,wx containers,compatible with 2.4,compatible with 2.6),
and your program used 2.8 (no debug,Unicode,compiler with C++ ABI 1002,wx containers,compatible with 2.6).
Aborted
Grimm
Thanks Macrob,
My arch is a AMD X2 4000 dual core. According to yum I'm updated to the latest versions, at least as far as the repositories are concerned.
Maybe I'm running a version that is too new?
yum list gtk2
Installed Packages
gtk2.i386 2.12.5-1.fc8 installed
gtk2.x86_64 2.12.5-1.fc8 installed
yum list wxGTK
Installed Packages
wxGTK.i386 2.8.4-6.fc8 installed
wxGTK.x86_64 2.8.4-6.fc8 installed
Grimm
- joegiampaoli
Users browsing this forum: Majestic-12 [Bot] and 206 guests
