proble with maxigo 1.09.6
i've render a my old scene and i've a problem with maxwigo 1.09.6 with render region...
- 1°.jpg (1.14 MiB) Viewed 5264 times
The initial image must also use the same settings as the one with a region.
So you also can't use reinhard for the big image too. Otherwise your settings would be different and the brightness of the output would also be different (as seen on your images). Set tonemaping to None for both and tweak your brightness by using the F-stop, ISO, Shutter etc.
- Kosmokrator
i think its ok with out the reinhard function!!what exactly is your problem?i work with new exporter for a few hours and looks quite stable and bug free....
