Blendigo for v1.0.9
SmartDen
Blendigo for v1.0.9
Post by SmartDen » Tue Apr 08, 2008 3:52 am
Requirements:
- Blender 2.45
- Python 2.5
- Indigo v1.0.8 or 1.0.9
Installation:
- Place Blendigo in ./blender/scripts
- Dont forget to edit IndigoWrapper.conf to specify your indigo location and put it in ./blender/scripts/bpydata
- put preview in the indigo directory
or use installer
Blendigo is continue developing
Update 23.05.2008
- External material support fixed
- "Auto Choose Thread" button added
- "Override" button added
Update:
- Linux build will be started with GUI
Bug Fix:
- DupliVerts and DupliFaces objects will be exported as instances
- Sphere and Plane primitives work now
- Bump export for Oren-Nayar shader
Windows Installer Blendigo_v109.exe
Zip blendigo_v109.zip
Skript for manually update blendigo_v109.py
Check normals, dude!
delic
Post by delic » Tue Apr 08, 2008 4:04 am
yeah ! Nice !
Vanessa07
Post by Vanessa07 » Tue Apr 08, 2008 4:32 am
Thanks SmartDen :D
Post by BbB » Tue Apr 08, 2008 4:47 am
Fantastic. Thanks.
jurasek
Post by jurasek » Tue Apr 08, 2008 4:48 am
... Normal was not unit length. fixed?
<vertex pos="-4.141155 -1.603915 0.000000" normal="nan nan nan" />
after 'remove doubles' it's ok.
greetz,
jur
normal_error.zip
.igs and .blend
(286.13 KiB) Downloaded 924 times
Sebastian
Post by Sebastian » Tue Apr 08, 2008 5:21 am
tank you VERY much ! glad to see ...
Anthor
Post by Anthor » Tue Apr 08, 2008 5:30 am
Tank You SmartDen :D :D :D
aleksandera
Post by aleksandera » Tue Apr 08, 2008 6:47 am
Thank you!
Will try it!
Regards,
Aleksander
tobak30
Post by tobak30 » Tue Apr 08, 2008 7:03 am
i cant seem to find the blendigo exporters in my script windows inside of blender. Even though i put it under scripts in my scripts folder in linux. I was so happy to see the linux build come and then where are my exporter? Could this be a blender problem or a linux problem?
neepneep
Post by neepneep » Tue Apr 08, 2008 8:29 am
.sphere primitive doesn't work for me.
exporting object "Sphere.sphere"
material [Material "Phong"] found
  File "<string>", line 3010, in buttonEvt
  File "<string>", line 2325, in exportStill
  File "<string>", line 2303, in export
  File "<string>", line 2181, in exportIndigoScene
  File "<string>", line 1713, in exportObjects
  File "<string>", line 1638, in exportObject
  File "<string>", line 1429, in getBoundingBox
TypeError: 'Blender MVert' object is unsubscriptable
ALso, using 'export to animation' doesnt want to work :cry:
INDIGO EXPORT
start 1 end 10
exporting frame 1
Object Sphere in layer 1
Object Plane in layer 1
Object Lamp in layer 1
Object Empty in layer 1
Object Camera.001 in layer 1
Object DonutTurd in layer 1
exporting object "Sphere"
  File "<string>", line 2944, in drawGUI
  File "<string>", line 965, in materialGUI
  File "<string>", line 2976, in drawButtons
  File "<string>", line 2949, in drawScreenButtons
  File "<string>", line 2328, in exportAnim
  File "<string>", line 2270, in export
  File "<string>", line 1630, in exportObject
AttributeError: 'str' object has no attribute 'write'
pixelminer
I can't export out animations either.
Post by pixelminer » Tue Apr 08, 2008 11:11 am
I can verify that the "export to animation" button gives the same errors as listed below.
bummer...
phong.
Pinko5
Post by Pinko5 » Tue Apr 08, 2008 7:19 pm
Tnx Smart!!!
Luca ;)
Vanessa07
Post by Vanessa07 » Tue Apr 08, 2008 7:33 pm
neepneep
I have exactly the same error message with the two last version of blendigo :(
SmartDen
Post by SmartDen » Tue Apr 08, 2008 8:52 pm
Thanks for feedback, fellows! You can sure understand, that i cant test all features... so it can happens that one or another don't work. i'll fix it ASAP
SmartDen
Post by SmartDen » Tue Apr 08, 2008 9:16 pm
Update. Linux get now a GUI
Users browsing this forum: Yandex [Bot] and 24 guests
