physically correct ?
8 posts • Page 1 of 1
Phil
Post by Phil » Tue Nov 07, 2006 2:32 am
Hello,
can someone tell me if this is a bug?
The black border does not seem ok for me.
Regards
Phil
skypa
Post by skypa » Tue Nov 07, 2006 2:43 am
I'd say those normals are facing the wrong direction. I don't know what modeler you use, but try flipping all normals to the outside.
Phil
Post by Phil » Tue Nov 07, 2006 2:57 am
Thanks skypa,
I will check the normal this evening, but I don´t think they are wrong.
I use Pro/Engineer as modeller and than I export in obj, then Blender and then Indigo.
For me it could be a shadow, but it really looks strange.
The 2 parts have nk material and are very reflective, could this be a problem?
I wil ljust try to render the picture longer, perhaps this will help.
regards, Phil
atmmatt
Post by atmmatt » Tue Nov 07, 2006 3:22 am
Have you tried rendering it in blender and seeing if the same problem is there?
Also which two nk files did you use?
"To be, or not to be" That is a question?
Lotuspec
Post by Lotuspec » Tue Nov 07, 2006 3:25 am
You could also try to render it with a diffuse material or other light conditions to see whether it is a normal or lighting (shadow) problem.
m1j
Re: physically correct ?
Post by m1j » Tue Nov 07, 2006 5:36 am
[quote="Phil"]Hello,
[img]http://img62.imageshack.us/img62/1700/test1xt2.png[/img]
Regards
Phil[/quote]
Is there a space between the mirrored disk and the mirrored support brackets? If there is a space then the dark area may be the space not getting light. Or reaching the max bousnce amount. Just a thought. Us a diffused surface to see what that looks like.
Phil
Post by Phil » Tue Nov 07, 2006 6:15 am
Hi m1j,
yes theres is a space, I am just investigating this.
What do you mean with "reaching the max bousnce amount"
@ all, is in indigo the same problem like in povray when we have too much reflective surfaces?
regards, phil
Phil
Post by Phil » Wed Nov 08, 2006 5:10 am
I made some new render, and I changed the material bracket.
in the first picture the material were:
<phong>
<nk_data>nkdata/Al.nk</nk_data>
<exponent>4000</exponent>
</phong>
for the bracket and
<phong>
<nk_data>nkdata/Cr.nk</nk_data>
<exponent>9000</exponent>
</phong>
for the wheel
Now I changed the bracket material in:
<phong>
<diffuse>0.7 0.7 0.7</diffuse>
<specular>0.149 0.149 0.149</specular>
<fresnel_scale>0.800</fresnel_scale>
<exponent>320.000</exponent>
</phong>
Here is the result
Now I can clearly see that there is a shadow, it is not black anymore.
It is a bit difficult to find the good parameters.
Thanks for you reply,
Phil
