Cindigo 1.0.8
Cindigo 1.0.8
Post by fused » Thu Mar 20, 2008 10:31 am
CINDIGO 1.0.8
for Indigo 1.0.8 (works with 1.0.9 stable)
(a quick test for low IOR phong with specular_reflectivity_spectrum and Oren Nayar)
download exporter:
PC Version
(or below)
Have a look at my Cindigo Blog! (about cindigo, and one or two other smaller plugins, which will come soon)
The file contains PC versions for R10 and R9. (R10 users will have to rename the "cindigo1.0.8.cdl_R10" to "cindigo1.0.8.cdl")
Make sure you have the newest version of quicktime installed!
Good beginner tutorials can be found here (german and english)
new in 1.0.8:
* Support for Oren Nayar Mat
* Support for specular_reflectivity_spectrum in Phong Mat
* Render Settings Tag now is an object!
fixed in 1.0.8:
* will not crash if no UVW tag is applied
* maybe some other small things
known bugs/issues 1.0.8:
* Blend material issues with blend maps
* better not use previews
features to come in the future: (for preventing double and tripple requests)
* Better .obj export (still needs optimization)
* Region rendering
Cindigo 1.0.8.zip
Cindigo 1.0.8
(1.11 MiB) Downloaded 1025 times
Post by pixie » Thu Mar 20, 2008 11:44 am
Super! :-)
Post by Zom-B » Thu Mar 20, 2008 8:50 pm
not a single day pasted since the Indigo update and we C4D guys already can play with the new features.... niiiiiiccceeee!!!
Marcofly
Post by Marcofly » Thu Mar 20, 2008 9:42 pm
Thank you very much, fused!
unfortunately i don't have time at the moment to use c4d and Cindigo :cry:
Ciao!!
Camox
Post by Camox » Thu Mar 20, 2008 10:51 pm
That was really fast. Thank you ! :D
greetz :wink:
Azrael Crusader
Post by Azrael Crusader » Fri Mar 21, 2008 9:52 am
Thanks fused, really nice.
meisteruli
Post by meisteruli » Sun Mar 23, 2008 2:41 am
Thank you
Post by fused » Tue Mar 25, 2008 1:59 am
nothing new here. i should put in more bugs... ;)
Post by pixie » Thu Mar 27, 2008 3:55 am
REQ: Would it be possible to take the layers name into consideration? Whereas sometimes one might use the same name for different materials they would distinguished by their layer name.
Sayris
Post by Sayris » Thu Mar 27, 2008 8:53 am
Thank you fused :wink: it's great.
Micha1138
Post by Micha1138 » Fri Mar 28, 2008 9:59 am
pixie wrote:REQ: Would it be possible to take the layers name into consideration? Whereas sometimes one might use the same name for different materials they would distinguished by their layer name.
I guess that is a new feature in C4D10.5 ? I´m still running 9.1 here, so I´d be happy if "special features" such as the one mentioned aren´t supported. Downwards compatible is the key to success ;) I´m still p.o.éd that Maxon didn´t care about data exchange between 9 and 10 versions :-(
Michael
Post by pixie » Sat Mar 29, 2008 2:47 am
Well.. it's on 10, it's a bit selfish of you not wanting features because you don't have those, namely because at least this one wouldn't have impact on cindigo UI, just on export process, it's something that if present (and not forgetting there's a 10 compile already) it could acknowledge it. Then perhaps we should not use any of 9 features for the sake of C4d 8 users. :roll:
Post by fused » Sat Mar 29, 2008 5:02 am
@pixie and micha:
actually i dont like to implement stuff thats not in R9, since having two different versions is pretty complicated.
the changes in the R10 build are minor (two functions i use changed their name in R10).
cant you just use unique names?
if not
maybe i can implement it, ill have a look in the docs and if its easy to find out in wich layer the material actually is... ill do it.
Post by pixie » Sat Mar 29, 2008 5:24 am
It's just so one doesn't keep materials with the same starting name once and again, having dozens of materials, having layers and not using them or using them as if they did not exist is a bit cumbersome.
Added:
Putting a more though on the matter perhaps layers aren't really needed, just like Cinema can use the same name for materials it might use an akin system for naming the materials, namely when one has to work always with the original and exporting it, the names doesn't really matter as long as they aren't mixed up. This way those who layers could use them without fear, and those who doesn't have that feature available might as take advantage of the fact of having a 'self-aware' material.
Micha1138
Post by Micha1138 » Thu Apr 03, 2008 8:10 am
Reading pixie´s last post makes my head hurt :lol:
At the moment it seems there´s not so much missing in the exporter when it comes to implementing C4D-stuff.
So what´s the next logical step ? What´s missing that Indigo has and C4D doesn´t need to export from a model ?
Michael
P.S.: Dang, I still haven´t figured out how to set up that Indigo cam for 9.1 which was provided by Wlad
Locked
Users browsing this forum: No registered users and 61 guests
