SkIndigo 1.0.8
- kwistenbiebel
previews
@ Richard: you're right.
You can get version 0.9 here: http://www.indigorenderer.com/joomla/fo ... php?t=2823
that release includes also the preview folder.
you can then overwrite the v0.9 files with the files in the latest release.
I'd suggest Whaat to repack the files in latest version correctly: all the files from preview folder are in the SKIndigo folder, & there's been some change in the ruby script that's made the presets option disappear from menu.
Re: previews
Thanks mate I already had 1.0.9 installed but still no previews folder there either.gautxori wrote:@ Richard: you're right.
All I get if I lauch anything from the plugin is as in the case of the material editor 102 error dialogue (counted them all this time) boxes that need to be each closed individually.
I read in another thread that kwisten had reset IE and that worked but all it did for me was loose all my passwords and browser history - still have 102 error dialogue boxes to close now! grrr!
Re: previews
Could be an installation problem.Richard wrote:Thanks mate I already had 1.0.9 installed but still no previews folder there either.gautxori wrote:@ Richard: you're right.
Make sure you have 'SkIndigo.rb' and the 'SkIndigo' folder in your Plugins directory. There should be a bunch of html files in the SkIndigo folder (among other things)
Thanks Whaat
Yes mate I have the rb and the full SkIndigo folder there!
Upon first launch of SU it asks me to locate the Indigo.exe and that then creates a path to text file in the directory.
If I click any option under the Skindigo drop down menu IE launches and so do between 45 and 102 error dialogues suggesting there is a scripting error! Each dialogue numbered differently.
I'l try putting the Indigo 1.0.8 folder in there too and see if that makes any difference!
The Skindigo folder contents. Note the "previews set - readme" reads as follows:
Previews set to use with SkIndigo.
Feel free to use/modify/share as you want.
1) Installation :
Copy the previews folder to the Indigo directory
2) Options
You have a few options you can change : lighting setup (studio or environment map), and indigo logo display.
See "previews set - options.txt".
1) Installation :
2) Options
- SkIndigo-Folder.jpg (71.82 KiB) Viewed 13623 times
WTF did you do???
Why is SkIndigo_1_0_8.rb in a folder called SkIndigo_1_0_8???
1) You should have SkIndigo_1_0_8.rb in your PLUGINS folder.
2) There is NO SkIndigo_1_0_8 folder!! The folder should be named 'SkIndigo'. That's it. I think the problem you are having is that SkIndigo is trying to find the support files in the 'SkIndigo' folder but for some reason, your folder is named 'SkIndigo_1_0_8'
There seems to have been a mistake when you unzipped the plugin or when you copied it into the Plugins folder.
I hope this solves your problem. Maybe it would be best to delete everything and start over...
Ahhhh!!!!!
I'll try that mate thanks! The zip was called SkIndigo_1_0_8, I just unzipped it and as one would expect it kept the same name! I didn't know I had to rename the Skindigo Folder before dropping it in the Plugins folder.
I left a copy of the ruby in the folder and just copied it accross to the plugins folder (one level up).
I'll see how I go this time!
Thanks again mate!
Thanks again mate!
Mate that worked a treat, just renamed the folder in the plugins folder.
Could I suggest: Zip folder named SkIndigo_1_0_8.zip contains,
1. SkIndigo Folder
2. SkIndigo_1_0_8.rb
3. Readme.txt
Will save the confusion.
Hey by the way mate amazing work on the new plugin dialogue boxes!!! You have set a new standard there!!!! The tool tips are cool! And explain a lot!
1. SkIndigo Folder
3. Readme.txt
Users browsing this forum: No registered users and 61 guests
