dougal2
by dougal2 » Sat Mar 29, 2008 5:19 am
That's not what Ono asked.
try indigo_console.exe
Vanessa07
by Vanessa07 » Sat Mar 29, 2008 5:27 am
It open and close the window in 0.001 second, I can't make screenshot, not enough time
dougal2
by dougal2 » Sat Mar 29, 2008 5:28 am
open the terminal first and then run it like you did before.
Vanessa07
by Vanessa07 » Sat Mar 29, 2008 5:32 am
It doesn't work, it try to open a new terminal
ViennaLinux
by ViennaLinux » Sat Mar 29, 2008 5:58 am
start - run - cmd.exe
then you have have terminal open... now type the indigo_console.exe command (make sure the path is right)
delic
by delic » Sat Mar 29, 2008 5:59 am
by OnoSendai » Sat Mar 29, 2008 6:07 am
Ok, I think the problem is that indigo.exe still has a dependency on the VS8 C runtime. I'll rebuild it to get rid of that.
In the mean time, use indigo_console.exe, or move the files
Microsoft.VC80.CRT.manifest, and the ms....dll's from v1.0.8 dir to the v1.0.9 dir.
delic
by delic » Sat Mar 29, 2008 6:09 am
It works ...
When adding a path to a file ...
no default scene anymore ?
delic
by delic » Sat Mar 29, 2008 6:17 am
Phoenix
by Phoenix » Sat Mar 29, 2008 3:53 pm
OnoSendai wrote:
* Compiled with VS2008
Do you use the express edition?
If yes, how do you managed to compile the 64bit version with it?
by OnoSendai » Sat Mar 29, 2008 6:44 pm
EDIT: updated links in original post to point at new build
People having problems please try these new builds out, and report if it works or not.
delic
by delic » Sat Mar 29, 2008 7:33 pm
It works fine with the updated x64 version on xp64 !
by OnoSendai » Sat Mar 29, 2008 7:33 pm
Great!
delic
by delic » Sat Mar 29, 2008 7:36 pm
Thanks Ono !
Wedge
by Wedge » Sat Mar 29, 2008 8:08 pm
Hello,
Nick: I tried launching the indigo_console version 109 with diffuse transmitter test scene but it failed with the same error. I also tried new version 1092 and both console/gui programs still fail with "this program has encountered an error and needs to close" event. Hope this report helps you.
Users browsing this forum: No registered users and 129 guests
