Indigo 1.0.9 (1.0 stable)
- Kosmokrator
Hey Ono... I did some banchmarks between 1.0.8, a.0.9 & 1.0.9 64bit.OnoSendai wrote:Nothing particularly cool about it, just the next compiler from MS.
I haven't really done many tests comparing speed. The new 64 bit build works pretty fast on some workloads, tho.
The results aren't what I expected :/
Indigo 1.0.8 = 100%
Indigo 1.0.9 = 99.42%
Indigo 1.0.9 64bit = 100.23 %Prozess priority to HIGH, so Indigo don't get slowed down by anything on my System.
By repeating the benchmark there seems to be a differance for each run of +- 0.2%
Where is the ~10% speed up using 64bit gone???
Maya To Indigo v1.0.9 Stable
http://www.indigorenderer.com/joomla/fo ... hp?id=4463
Hello,
I have been quite busy lately but I have downloaded Indigo 108 and 109. 109 errors as soon as I run it on WinXP 32bit with one of those "this program has encountered an error and needs to close" errors.
108 launches fine but I will admit I have not started a render with it yet. My last render test was performed on version 106 I think. (106 runs fine)
I hope this bug report helped.
Probably something to do with the new VS2008 project?
Can you try running indigo_console.exe, instead of indigo.exe.Wedge wrote:Hello,
I hope this bug report helped.Probably something to do with the new VS2008 project?
Does it give the same error?
I have some problem whit 64 bit version.....32 bit work very well...
I am using vista 64 whit 3d studio 2008 64 whit pc 2xQuadXeon.
which can the problrma be?
filippo
filippo
- errore message
- indigo error.JPG (113.16 KiB) Viewed 7957 times
Users browsing this forum: No registered users and 153 guests
