Indigo 1.0.9 (1.0 stable)
Post by OnoSendai » Fri Mar 28, 2008 2:18 am
This release will be first 'stable' release for 1.0
EDIT: updated links to point at new builds which should hopefully fix the 'application needs to be resinstalled problem'
EDIT: updated 32 bit build again
Windows 32 bit:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
Windows 64 bit:
changelog:
1.0.9
* Fixed zero diffuse with phong when using albedo texture + specular reflectivity spectrum.
* Compiled with VS2008
EDIT:
Exporter authors: Please reply to this thread with a link to your current exporter for 1.0, and the name of the exporter and version. This is for making the main download page. Thanks!
SmartDen
Post by SmartDen » Fri Mar 28, 2008 2:19 am
thanks master!
filippo
Post by filippo » Fri Mar 28, 2008 2:24 am
wooooooderfull work........
filippo "radiosity" :D :D :D
Post by Zom-B » Fri Mar 28, 2008 2:58 am
Very nice, so a new version Number means also some new experimental stuff for Indigo...
I'm very interested what Master Ono will surprise use with :D
btw: what is so cool about "Compiled with VS2008"?
dougal2
Post by dougal2 » Fri Mar 28, 2008 3:00 am
Cheers Ono,
I have a slightly updated MtI at home that implements all the remaining renderer_settings. I'll post it as v1.0.9 later on today or tomorrow.
Post by OnoSendai » Fri Mar 28, 2008 3:01 am
Nothing particularly cool about it, just the next compiler from MS.
I haven't really done many tests comparing speed. The new 64 bit build works pretty fast on some workloads, tho.
Pinko5
Post by Pinko5 » Fri Mar 28, 2008 3:20 am
Tnx ONO!!!
Luca. ;)
palawat
Post by palawat » Fri Mar 28, 2008 4:08 am
Thank you, Ono.
SmartDen, I'm looking forward to your Blendigo 1.0.9 :wink:
Cheers,
jurasek
Post by jurasek » Fri Mar 28, 2008 4:26 am
Cheers! Linux build on the way? ;)
greetz,
jur
SmartDen
Post by SmartDen » Fri Mar 28, 2008 4:46 am
palawat wrote:Thank you, Ono.
Soon. but first i want build in all suggestions from manitwo and Ono
Camox
Post by Camox » Fri Mar 28, 2008 4:58 am
Thank you ! :D
Vanessa07
Post by Vanessa07 » Fri Mar 28, 2008 5:52 am
So Great
THANKS :D
Vanessa07
Post by Vanessa07 » Fri Mar 28, 2008 6:11 am
does it work with xp 64
mario
SSE1?
Post by mario » Fri Mar 28, 2008 7:28 am
Don't work with SSE1?
Post by Whaat » Fri Mar 28, 2008 8:20 am
Thanks again Ono!
SkIndigo 1.0.8 (Beta)
