I hope you didn't 'cheat' to find itcpfresh wrote:the easter egg is pretty cool, i don't typically use that feature of sketchy... but maybe now I will!!Awesome
SkIndigo 1.0.8
ROFL i admit i found it in the code.
i was adding some "-n wm" to the batch.puts to make indigo always run as working master [instead of normal mode] and i also added a reference to the location of my Skindigo Folder [on my net] so i can render previews via wm as well ... while doing that i came across the egg ... :/ sorry!
- kwistenbiebel
But has anyone figured out how to access the egg from the UI?? Hint: It can be done via the 'Render Settings' dialog.cpfresh wrote:ROFL i admit i found it in the code.
Whaat,
Question regarding a "clay" render, just tried it and for some reason Indigo was still showing all the materials and textures being loaded ... is that right? Seems like none of that should be in the igs file exported from SketchUp when using the "clay" option.
Also, I was wondering if it would be possible to add an option to cancel export when an error occurs. For example, just now I hit export and one of my blend files was misnamed and so the reference was missing. There's a pop-up that occurs to let me know, but then the export still continues and there's no way to stop it and fix it until Indigo gets the file and errors out itself. So, I'm wondering, can you add an option on error like, "Continue with export?" Yes/No or something? In the case of large files, it could save some time.
Thanks for your input and this awesome exporter!
