Indigo 1.0.7
SmartDen
Post by SmartDen » Wed Mar 12, 2008 4:32 am
Photoguy wrote:I might have found a problem, it tried with an older version and it didn't do this.
Also here is the windows error report.
http://www.mediafire.com/?ymc95jluy9u
it is solved in blendigo 1.0.7. please download it
Big Fan
Post by Big Fan » Fri Mar 21, 2008 12:07 pm
ok question for ono:
I understand when supersample is 1 downsize filter is disabled...says so in the manual :wink:
so I made my exporter not write blur,ring etc for this situation but when the .igs loads in indigo it seems to load the default values anyway according to the blurb in the window- is that just the way it looks or is it being used anyway? and shouldnt it be the old box in that case?
also there seems to be a difference in brightness or such between say a supersample 2 with filter and supersample 1 without? filter .. is that right?
Post by OnoSendai » Fri Mar 21, 2008 2:40 pm
Big Fan wrote:ok question for ono:
It may not use the downsize filter when super sample factor is 1, but it still parses and displays the downsize filter parameters.
It should be the same brightness - make sure you leave the render for a while before you compare brightnesses.
Big Fan
Post by Big Fan » Fri Mar 21, 2008 3:00 pm
1.ok so there is no harm done by me not exporting it then I guess...
2.I guess it converges to much the same image just slightly different pixels then...I don't know if this has been noticed or mentioned before... might mislead people who do a quickie render to check render settings that their reinhard is off or something :roll:
Users browsing this forum: No registered users and 65 guests
