Error Problem
Error Problem
I am using 3DS max 9 32bit , indigo_v0.9.10 , Maxigo_0.9.4a i install it properly , when i open it first time it worked , as soon as i restarted it the problem came up plz need help how to fix it
- Error.JPG (8.62 KiB) Viewed 5452 times
Hmm..
Seems like there is a conflict and something (some plugin or another script) is using the same variable name as Maxigo. That's why it can't assign a value to it. I will rename the "frame" to "indigo_frame" or something in the next release.
Sry, but currently the only workaround for you would be to uninstall the plugin that causes the conflict
Error Problem
suvakas , Any update for my problem . i am still waiting for your reply pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Hey,
Try this. It's still version 0.9.4a, but I changed the "frame" variable to "indigo_frame".
See if it works for you.
Just overwrite the previous Maxigo.mse with the one in the zip package.
- Maxigo_frame_changed.zip
- (228.03 KiB) Downloaded 347 times
hurrrrrrrrrrrrrrrrrrrraaaaaaaaaaaaaaaaaaaaaaaa
Holy potato it worked , you are great man , now i can start use indigo with 3ds max again . 1000000000000000000x thanks
, what else can i say but to say GOD bless you suvakas and all indigo team
