I've always wondered: what is an "n-gon"? Polygon with more than 3 sides? Or more than 4 sides?dougal2 wrote:Triangles are your safest option, but I think some n-gons will also work - be careful with normals and how the polys are modelled in particular.
export for houdini
I think it's actually a generic term for a polygon with any number of sides,
http://www.mathwords.com/n/n_gon.htm
I tend to use it to mean 4 or more.
Ah, so you're not meant to say the "n", you're meant to substitute a number in there. Otherwise its identical to "polygon", I take it.dougal2 wrote:I think it's actually a generic term for a polygon with any number of sides,
Thanks for the clarification.
I guess it depends on the definition. A n-gon is a polygon, no matter what.
We just need to clarify things a bit more to make our communication a bit
easier. So in our case (3D) we talk of n-gons when it comes to faces with
more than 4 vertices. And the most modelers try to avoid them as hell,
like tris too. Of course it always depends on the purpose of the model.
take care
psor
take care
psor
"The sleeper must awaken"
sounds good
Yeah, usually, quads are the best solution... for most purposes.
N-gons (as we now finally have defined them) can screw up the whole geometry in some cases... tris smooth out strange, sometimes, but they still kinda can be used
(And in case of Indigo, they're actually the only things, besides some special primitves, that you can use at all)
Just to let everyone know, I've made quite a bit of progress with the exporter. There are a few significant areas to still develop but the bulk of it has been done.
http://forums.odforce.net/index.php?sho ... entry44463
I'm having hassles where internal_mediums are rendering out just black. I would love for someone to examine some simple IGS file output for me and tell me where I'm going wrong. Is it my normal definition? Or a setting somewhere? Are there any common snafus that I might be missing? I'll post a snippet later tonight if someone volunteers to read it:)
Also, I'd love for someone to with experience on how to map, say, .mi or .rib camera parameters to the Indigo camera. I've gotten part of the way there but my settings aren't quite there yet since I don't quite have a good mapping of the standard Houdini camera to the Indigo camera. (I figure people are more likely to be familiar with Renderman or mental ray than Houdini...)
Cheers,
Jason
Cheers,
Jason
looks like you're making good progress
For working with the camera, check out the exporter writer's guide here:
http://www.indigorenderer.com/joomla/fo ... php?t=1106
There are a few requirements for media objects:
* surface must be closed with no holes
* geometric normals must point out
* lights must not intersect the surface of media objects.
* precedences must be set correctly
See the appendices of the Indigo manual for more info.
Hey there,
Thanks for the information!
I didn't get around to doing anything on this last night but I do have a couple more questions:
*/ If there any way to pipe the IGS directly into Indigo? Most renderers I've use can read stdin and so Houdini just writes away and the renderers pick it up. So far it seems that indigo.exe cannot do this and I might have to write a wrapper for indigo - which I'd prefer not to do.
*/ An installation question: what is the best way to install Indigo? It seems that if I attempt to invoke it from another cwd it will fail as it doesn't seem to search for its setup files relative to the binary path. Ideally I'd like to just add the indigo.exe location to the $PATH and thats that (just pipe to indigo.exe) - everything *should work. Can you explain or point me to a good document for this?
Take care,
Jason
Take care,
Jason
I got the mediums to work - it turns out my polygon winding needed to be reversed. Thats good news!
I updated to 1.0.7 and found that the "white_balance" camera tag seems to bork the parser now. It seems like I've added it in the manner described in the PDF file but it doesn't like it. (I renamed it from "whitebalance" under "render_settings" to "white_balance" under "camera" - it used to work in the stable release 0.9.7)
And I also think the russian_roulette_live_prob doesn't work either. (Also renamed from 0.9.7)
If I comment these both out things go through.
Hey there,OnoSendai wrote:There's no way to pipe the IGS directly to Indigo (unless you are using the commercial SDK).
Do you think that you'll support piping into Indigo some day? Why I ask is that it's pretty convenient if it can do done this way.
On the good side, the setup is almost ready for any early adopters to give it a whirl - just a couple of niggly things left to do (like fix slight oddness with my camera parm translations).
Cheers,
Jason
Users browsing this forum: Baidu [Spider] and 78 guests
