Protoestudios
yonosoy
Re: Protoestudios
Post by yonosoy » Thu Sep 28, 2023 11:09 pm
It is a pleasure to find that other people are able to appreciate these differences that are so expensive to obtain.
Indigo is capable of being unlike anything else known.
I send you the first shot with the time of the third... Those suspension cables... Yes.
2K
4K
yonosoy
Re: Protoestudios
Post by yonosoy » Thu Sep 28, 2023 11:17 pm
I also like so much the photo-noise with black and white. It is like the photo-quimic grain of the films... but better than with the plugins...
Polinalkrimizei
Re: Protoestudios
Post by Polinalkrimizei » Fri Sep 29, 2023 7:29 pm
Thanks man, that's fantastic.
It touches me in two dimensions - as a "simple" photograph as well as on a technical level with a truly virtual camera.
yonosoy
Re: Protoestudios
Post by yonosoy » Fri Sep 29, 2023 10:55 pm
So many thanks for the warm.
A study in process. Atmospheric simulation.
I need to locate which programs will I need to aproximate it more (in terms of texture maps, textures of the materials and to paint they in photoshop...). Also the welding points.
The floor is good, Oren Nayar (maybe a sutil blend whit a mostly mate phong). Less displacement in the second approximation.
The design of the piece was change at last time in the materialization. This is closer to initial sketches. It´s easy to modify, also to "organice" it.
In focus terms I will also approximate the photograph. Diaphragm more opened in the second approximation.
The principle rules of light and color are present.
yonosoy
Re: Protoestudios
Post by yonosoy » Sun Oct 01, 2023 4:57 am
Process image.
Superposition.
yonosoy
Re: Protoestudios
Post by yonosoy » Mon Oct 02, 2023 6:35 am
I introduce an excess of lack of focus and trepidation (motion blur). Is a little bit strange...
I found substance painter very easy, and found z brush for the welding points very difficult...
Still a final shot pending.
4 hours.
In this one is remarkable the simulation of the shadows, less dense and more blue along the path...
12 hours, a bit downsized.
yonosoy
Re: Protoestudios
Post by yonosoy » Mon Oct 02, 2023 1:04 pm
Protoestudios (trepidante protección).
yonosoy
Re: Protoestudios
Post by yonosoy » Fri Oct 06, 2023 11:33 am
24 hours of rendering...
yonosoy
Re: Protoestudios
Post by yonosoy » Wed Oct 11, 2023 6:32 pm
I don´t advise that this thread has the same dinamyc as all the rest, more work in progress than a finished one.
18:30.
I will render this one till the point of print.
Sigma 56 mm, 8K.
Polinalkrimizei
Re: Protoestudios
Post by Polinalkrimizei » Thu Oct 12, 2023 4:05 am
Beautiful.
And funny - while today your approach is a beautiful and probably the most comlicated method to emulate analog results, it may one day be the only way.
Pretty cool!
yonosoy
Re: Protoestudios
Post by yonosoy » Thu Oct 12, 2023 9:17 pm
Thanks for understand...
Is a pleasure.
yonosoy
Re: Protoestudios
Post by yonosoy » Fri Oct 13, 2023 10:12 pm
16:30.
The same, I will render it to print.
Sigma 56 mm, 8K.
yonosoy
Re: Protoestudios
Post by yonosoy » Sat Oct 14, 2023 10:55 pm
Protoestudios (catedral) 01.
9:30, 1500 spp.
Motion blur works really well, the ortographic camera needs a cinema tag...
yonosoy
Re: Protoestudios
Post by yonosoy » Mon Oct 16, 2023 12:19 am
Light!
I will process this one to print too.
yonosoy
Re: Protoestudios
Post by yonosoy » Wed Nov 08, 2023 5:30 am
Sigma 56 mm objective. Focus plane stabilished.
F-stop 8.
30 hours. 8K format.
APS-C frame (25.1 mm), panavision.
Canon 24 mm objective recovered.
F-stop 8.
30 minutes. 8K format.
APS-C frame (25.1 mm), vertical panavision.
There is a lack of protections in the proyect. Maybe elevators system more detailed, a nude ladscape, etc...
A protostudy. :)
Another take with F-stop 16 in color...
8 hours.
Canon 24 mm objective.
F-stop 16.
8 hours. 8K format.
There is a lack of union elements in the proyect. Etc...
A protostudy. :)
