Protoestudios
Re: Protoestudios
It is a pleasure to find that other people are able to appreciate these differences that are so expensive to obtain.
Indigo is capable of being unlike anything else known.
I send you the first shot with the time of the third... Those suspension cables... Yes.
Re: Protoestudios
I also like so much the photo-noise with black and white. It is like the photo-quimic grain of the films... but better than with the plugins...
- Polinalkrimizei
Re: Protoestudios
Thanks man, that's fantastic.
It touches me in two dimensions - as a "simple" photograph as well as on a technical level with a truly virtual camera.
Re: Protoestudios
So many thanks for the warm.
A study in process. Atmospheric simulation.
I need to locate which programs will I need to aproximate it more (in terms of texture maps, textures of the materials and to paint they in photoshop...). Also the welding points.
The floor is good, Oren Nayar (maybe a sutil blend whit a mostly mate phong). Less displacement in the second approximation.
The design of the piece was change at last time in the materialization. This is closer to initial sketches. It´s easy to modify, also to "organice" it.
In focus terms I will also approximate the photograph. Diaphragm more opened in the second approximation.
The principle rules of light and color are present.
Re: Protoestudios
I introduce an excess of lack of focus and trepidation (motion blur). Is a little bit strange...
I found substance painter very easy, and found z brush for the welding points very difficult...
Still a final shot pending.
4 hours.
In this one is remarkable the simulation of the shadows, less dense and more blue along the path... 12 hours, a bit downsized.
4 hours.
Re: Protoestudios
Protoestudios (trepidante protección).
Re: Protoestudios
I don´t advise that this thread has the same dinamyc as all the rest, more work in progress than a finished one.
18:30.
I will render this one till the point of print.
Sigma 56 mm, 8K.
18:30.
Sigma 56 mm, 8K.
- Polinalkrimizei
Re: Protoestudios
Beautiful.
And funny - while today your approach is a beautiful and probably the most comlicated method to emulate analog results, it may one day be the only way.
Pretty cool!
Pretty cool!
Re: Protoestudios
Thanks for understand...
Is a pleasure.
Is a pleasure.
Re: Protoestudios
16:30.
The same, I will render it to print.
Sigma 56 mm, 8K.
Sigma 56 mm, 8K.
Re: Protoestudios
Protoestudios (catedral) 01.
9:30, 1500 spp.
Motion blur works really well, the ortographic camera needs a cinema tag...
9:30, 1500 spp.
Re: Protoestudios
Light!
I will process this one to print too.
Re: Protoestudios
Sigma 56 mm objective. Focus plane stabilished.
F-stop 8.
30 hours. 8K format.
APS-C frame (25.1 mm), panavision. Canon 24 mm objective recovered.
F-stop 8.
30 minutes. 8K format.
APS-C frame (25.1 mm), vertical panavision.
There is a lack of protections in the proyect. Maybe elevators system more detailed, a nude ladscape, etc...
A protostudy.
Another take with F-stop 16 in color...
8 hours. Canon 24 mm objective.
F-stop 16.
8 hours. 8K format.
There is a lack of union elements in the proyect. Etc...
A protostudy.
F-stop 8.
F-stop 8.
A protostudy.
F-stop 16.
8 hours. 8K format.
A protostudy.
Users browsing this forum: DotBot [Bot] and 7 guests
