Alami Rendering Thread
Re: Alami Rendering Thread
The House
By the way, it looks like you are using the dscs315 camera filter (dark shadows and medium contrast)
for archiviz I recommend using custom camera presets:
Eastman-Double-X-NegCD5min
optura981113
gamma+0.4
gamma+0.6
(for bw)
and default
agfacolor-futuraII-100CD
Portra-800CD
indigo export .exr > photoshop > 32 bit to 16 bit (exposure and gamma) > open any .dng color preset ( example https://disk.yandex.ru/d/lb6e-xCYBLF-4Q ) > drag n drop .dng to photoshop > CTRL + C > open indigo rendered .exr image > Filtres — Camera Raw Filtres > CTRL + V
optura981113
gamma+0.4
gamma+0.6
(for bw)
and default
Portra-800CD
- dorfCurves.zip
- (2.52 MiB) Downloaded 1514 times
Final Shots
Thanks for these info.Zalevskiy wrote: ↑Tue Apr 25, 2023 8:53 amBy the way, it looks like you are using the dscs315 camera filter (dark shadows and medium contrast)
optura981113
gamma+0.4
gamma+0.6
(for bw)
and default
Portra-800CD
I'm using agfapan-apx-100cd.
The Water-Front House
California House Landscape
Sometimes there are ups and downs, cheer up!
I can´t see architecture here, I can´t see nothing here, ...
Maybe this one is from time ago...
A suggestion: desaturate a bit some texture maps (vegetation in this case). The color is very strong with this specific film...
Also try a ISl shader to vary the color from instance to instance of grass and trees. There is some in the forum and in my threads, but I don´t remeber now where and I don´t have it now. But for this you must use the internal scatter of indigo I thougt... It has adventages and difficulties.
There is a long explanation of use in h, try it if you have time...
Maybe saturation is not so strong, maybe the tone and the homogenic look...
But, a little bit less saturation is convenient for indigo mostly. For other engines the color is less powerfull than for indigo.
