i just ordered a quad core...
psor
Post by psor » Sat Jan 26, 2008 2:20 pm
@dougal2
Even if I'm a bit late, but I was wondering what settings you'd used.
e.g. ... PT; biPT; MLT; biMLT
take care
psor
"The sleeper must awaken"
dougal2
Post by dougal2 » Mon Jan 28, 2008 5:17 am
I used the diffuse_transmitter_test scene included with indigo as a benchmark, and all default settings (apart from setting num_threads to 4).
Grimm
Post by Grimm » Mon Jan 28, 2008 10:32 am
dougal2 wrote:WOO! machine did indeed turn up today.
Got XP32 and Vista64 on it already.
Did a quick speed test with 1.0.4 diffuse_transmitter_test test scene:
~ 210,000 samples per second.
I'm just going to have a look for a solution to why 0.9t4.5 64bit doesn't run then I'll post figures for that when I can get it running.
edit: 64bit version doesn't seem to be any faster.
I'd be interested you see other people's speed for this test scene, and what machine you ran it on.
Hi Dougal2,
I ran the diffuse_transmitter_test on my microwulf system but I'm not sure how to read the samples per second. Here is the output:
Display took 0.71327 s
Time elapsed: 1 m, 54 s
Done 14460000.00000 samples (53.55556 samples per pixel)
125899.28064 samples / second (7.94286 micro-seconds / sample)
saving tone-mapped image to 'renders/im1201472071.png'
done.
Display took 0.83701 s
Time elapsed: 2 m, 5 s
115044.11885 samples / second (8.69232 micro-seconds / sample)
Display took 0.71319 s
Time elapsed: 2 m, 16 s
106008.27084 samples / second (9.43323 micro-seconds / sample)
------receiving frame from 10.0.0.3:------
num_samples: 2720000.000000
width: 1200
height: 900
------frame received.------
My system consists of three nodes, each with a AMD X2 4000+ processor for a total of six cores. Do I add up the samples/second of all of them which would add up to 346951 samples/second or do you look at them separately? My samples seem to increase over time though, maybe it's the OS settling down?
edit: oops I forgot to add that I'm running the 64 bit linux build version 1.0.1 on Fedora 8.
Grimm
dougal2
Post by dougal2 » Mon Jan 28, 2008 11:40 am
you should look at the output on the master node, that includes all samples from all slaves. I would let it run for more than a few minutes though to make sure that all slaves have contributed. Or at least run it for longer than the frame_upload_period, maybe 2 or 3 times longer so that all slaves and the master have had a chance to run at full speed.
Grimm
Post by Grimm » Mon Jan 28, 2008 12:31 pm
Ok here is the output from the master node:
Display took 0.71033 s
Time elapsed: 33 m, 55 s
Done 381240000.00000 samples (1412.00000 samples per pixel)
187264.19077 samples / second (5.34005 micro-seconds / sample)
saving tone-mapped image to 'renders/im1201477283.png'
done.
Display took 0.92118 s
Time elapsed: 34 m, 6 s
186264.96229 samples / second (5.36870 micro-seconds / sample)
Display took 0.71049 s
Time elapsed: 34 m, 17 s
185295.31391 samples / second (5.39679 micro-seconds / sample)
------receiving frame from 10.0.0.2:------
num_samples: 2970000.000000
width: 1200
height: 900
I let it run for about a half an hour, but I'm still not sure how to read it. here is what the nodes reported for their samples:
node 1:
------Uploading frame------
Frame size: 12.360 MB
Num Samples: 2980000.00000
------frame uploaded.------
Approx. samples per second: 99333.33333
Num Samples: 2970000.00000
Approx. samples per second: 99000.00000
node2:
Num Samples: 2710000.00000
Approx. samples per second: 90333.33333
Num Samples: 2720000.00000
Grimm
dougal2
Post by dougal2 » Mon Jan 28, 2008 12:33 pm
is the master a "working" master, or just a non-rendering master ?
you should be able to get another 90k samples/sec if the master is working also.
start the master with the -n wm switch, and try again.
Grimm
Post by Grimm » Mon Jan 28, 2008 12:48 pm
I tried the -n wm switch but indigo complained:
./indigo_console -n wm testscenes/diffuse_transmitter_test.igs
Indigo Renderer v1.0.1, Linux 64-bit Release build.
usage:
indigo.exe [-n (s|m)] [-h hostname:port] scenepath.xml
Should I start another slave process on the master node?
Grimm
dougal2
Post by dougal2 » Mon Jan 28, 2008 12:53 pm
ah, I think -n wm is only for a more recent version.
A simple alternative is indeed to start a slave on the master, as you said.
Grimm
Post by Grimm » Mon Jan 28, 2008 1:30 pm
Darn, you mean to tell me that I have been running at only 2/3 capacity? :shock: Here is the output from the master process:
Display took 1.12389 s
Time elapsed: 34 m, 9 s
Done 558340000.00000 samples (2067.92593 samples per pixel)
272447.79421 samples / second (3.67043 micro-seconds / sample)
num_samples: 2980000.000000
width: 1200
height: 900
Display took 0.92981 s
Time elapsed: 34 m, 20 s
Done 561320000.00000 samples (2078.96296 samples per pixel)
272448.81699 samples / second (3.67041 micro-seconds / sample)
num_samples: 2710000.000000
width: 1200
height: 900
Thanks Dougal!!! :D
Grimm
dougal2
Post by dougal2 » Mon Jan 28, 2008 9:46 pm
that looks more like it :)
CoolColJ
Post by CoolColJ » Sun Feb 24, 2008 5:56 pm
still on a P4 here, might wait till 2009 for the new Intel 8 core CPU and Mothboards it will need before I upgrade :twisted:
Post by suvakas » Sun Feb 24, 2008 7:46 pm
Hey CoolColJ, life is too short to wait like that :wink:
2008 just began. Go get a quad now :)
psor
Post by psor » Sun Feb 24, 2008 8:25 pm
Yup, go for it! The cheapest node I could put together (in my mind) was like:
Intel DG33BU (mATX LGA775, max 8GB)         ~100,- Euro
Intel Core 2 Quad Q6600 FSB 1066                 ~210,- Euro
Kingston Value RAM PC 533 4096 (KIT 2x2GB) ~  90,- Euro
Imagine ten of them in a Beowulf cluster! *Hello Grimm!* ;o)
So ya, it's time to take the risk! The head node is not included! 8) :D ;)
take care
psor
Grimm
Post by Grimm » Mon Feb 25, 2008 9:09 pm
CoolColJ, I agree with suvakas, go for it. It doesn't take many nodes to get much better performance then from a single box (unless it has that 80 core IBM cpu in it :) ).
psor, 10 of those nodes would scream. :D 400 euros isn't too bad, what is that, about $600 US? That is about what 2 of my dual core nodes cost and it would perform better too. Although my cost ($300 US) also includes the case, power supply, and hard drive. :P :D
Grimm
psor
Post by psor » Mon Feb 25, 2008 10:13 pm
@Grimm
Hell ya, ... I probably would go without hdd and without a case.
I have to take a look at those really small PSU's, then I would
build the case on my own with all ten inside. :twisted: 8) :lol: :wink:
btw. this is just an idea in my head, but it gets more clear
every day. So lets see what happens at the end of the year.
I just have to remember you at the picture ... *whistle*
take care
psor
Once upon a time there was a small studio ...
