Alami Rendering Thread
Re: Alami Rendering Thread
Ok, I added the exit portal behind the window, but how can I show the environment behind the exit portal now.
I'm going to apply this method now, I tried again without the exit portal to show the environmentyonosoy wrote: ↑Wed Apr 19, 2023 10:15 amI explain you the method once again. In the simpliest manner possible...
Enclose your "room" in a box a little bit bigger than the room.
Apply to this box a specular material with an IOR of 1, a very little kind of absoption and a little amount of SSS (try Henyey Greenstein phase).
Put in the room a lamp with an "exit cone", it means that it isn´t be a "free light or a ceil light".
Turn the night on (only the night lights, without an environment).
In this way you reached volumetric lights.
Don´t sound easy enough?
Thanks, I want to know how to use the atmosphere and extra atmosperic sun, can I see any example for an interior with these real effects
Really do you follow my threads? Or is because this the low expectences or views of my threads?
