Alami Rendering Thread
Re: Alami Rendering Thread
Ok, I added the exit portal behind the window, but how can I show the environment behind the exit portal now.
I'm going to apply this method now, I tried again without the exit portal to show the environmentyonosoy wrote: ↑Wed Apr 19, 2023 10:15 amI explain you the method once again. In the simpliest manner possible...
Enclose your "room" in a box a little bit bigger than the room.
Apply to this box a specular material with an IOR of 1, a very little kind of absoption and a little amount of SSS (try Henyey Greenstein phase).
Put in the room a lamp with an "exit cone", it means that it isn´t be a "free light or a ceil light".
Turn the night on (only the night lights, without an environment).
In this way you reached volumetric lights.
Don´t sound easy enough?
Thanks, I want to know how to use the atmosphere and extra atmosperic sun, can I see any example for an interior with these real effects
Really do you follow my threads? Or is because this the low expectences or views of my threads?
Users browsing this forum: Google [Bot] and 102 guests
