Alami Rendering Thread
yonosoy
Re: Alami Rendering Thread
Post by yonosoy » Wed Apr 19, 2023 7:07 am
And now this:
by Alamy » Thu Jul 22, 2021 7:20 pm » in Finished Artwork
What happeens here?
Somebody can explain to me?
yonosoy
Post by yonosoy » Wed Apr 19, 2023 7:08 am
Now this, I paste and copy...
I´m crazy?
yonosoy
Post by yonosoy » Wed Apr 19, 2023 7:10 am
Again, this is the last, or no...
Is a witch question?
Alamy
Post by Alamy » Wed Apr 19, 2023 7:13 am
I think this is little bit strange.
Post by Alamy » Fri Jul 23, 2021 6:20 am
this was the date of my first post.
Alamy
Post by Alamy » Wed Apr 19, 2023 7:14 am
and this is my join date to the forum
Alamy
I only have 71 posts
yonosoy
Post by yonosoy » Wed Apr 19, 2023 7:18 am
Seems that tere are rats in the forum!
Excuses for my bad language some times. Is very recent.
I´m excited to help you, don´t doubt it!
Alamy
Post by Alamy » Wed Apr 19, 2023 7:28 am
no worries, It's ok
I really appreciate your help.
first I will send you the pigs file.
yonosoy
Post by yonosoy » Wed Apr 19, 2023 7:30 am
Now all the dates of my posts change...
Definetly I´m crazy and I don´t see well...
Or Somebady have acces to my accounts and this forum?
Is the pentagono? Cia? Fbi? Vacatione?
Am I persecuted?
Sorry for dirt your clean thread, really strange... Cada vez es más descarado... Te compensaré con ambiente y volumetría, aunque puede que tus clientes sólo quieran GPU.
I can´t work with a pigs! I need the scene or you must do it by yourself!
Alamy
Post by Alamy » Wed Apr 19, 2023 7:33 am
Ok, I will post screen shots to show you the problem I'm facing right now with Exit portals
yonosoy
Post by yonosoy » Wed Apr 19, 2023 7:36 am
Exit portals is not a good solution. Every time you reduce the accurancy of Indigo is a bad decision.
Exit portals don´t work well since too many time ago! But ONO explained some progresses don´t materialized some time ago.
yonosoy
Post by yonosoy » Wed Apr 19, 2023 8:19 am
What is the problem of render a overnight in MLT bidirectional mode with yhe pmoney that you earn with your work?
Is necesary to run so fast (two minutes)?
You don´t model the furniture, only the envelope of the rooms!
To play "saloncitos de pin y pon" is an easy way to get a life!
For me is impossible at the moment... even when I´m able to do it better than nobody else! (Or almost good).
Alamy
Post by Alamy » Wed Apr 19, 2023 9:00 am
I'm not using the exit portals to render fast, I'm just expermint with exit portals how to make the scene not to look dark in some areas, the Image that you see already doesn't have exit portals
this one has exit portal
Alamy
Post by Alamy » Wed Apr 19, 2023 9:01 am
but when I add the plane with material and assign exit portal for this material, the window behind this exit portal dissappear, I don't want to use exit portal, but I'm curios how to make this work for my info.
yonosoy
Post by yonosoy » Wed Apr 19, 2023 9:23 am
"the window behind this exit portal dissappear"
Now I see your skills...
Try to put the portal behind the window.
Don´t woorry, is a principiant fail :). Even when Indigo is the simpliest program to this kind of workflow, sometimes is easy to make a mistake...
330 views in 15 hours, impressive...
yonosoy
Post by yonosoy » Wed Apr 19, 2023 9:41 am
Put the exit portal in the outside of your room,
