Blendigo 1.0.5 Beta
Just exported a displaced plane from 32-bit blender (non LAA)
2097152 triangles
Worked great!
Thanks SmartDen! I've always loved Blendigo's UI.
EDIT:
Tried exporting again, this time with one more subsurf level, and blender crashes at Getting Matrix from <my object>.
So 2 million is a good idea of the limit for default 32-bit blender on windows.
Using the /LAA blender, it exports fine. (this is 8 million tris, btw)
However, Indigo crashes on trying to read the .igs (which is ~800 mb)!
We need an x64 build of 1.05+, Ono!
2097152 triangles
Worked great!
EDIT:
@psor: There isn't anything new in the Blendigo GUI to enable/disable it. I don't quite see how it's that big of a problem to hit the "Border" button though...
@alex
I thought of a short cut because SHIFT-B enables it. But as I found out
there is no way of doing it right now and that I'm not the only one who
got spoiled by it.
You see I'm a 3dsmax user, so I do almost have no clue about blender.
At least I'm able to learn which is an advantage, hehe!
take care
psor
got spoiled by it.
take care
psor
"The sleeper must awaken"
Ah, I see. Yeah, the thing you have to keep in mind is that Shift+B for border rendering is a blender feature, so all of the controlling of it is in blender's options. SmartDen was simply able to tap into the data for it through the python API.
@neepnepp
You're right, it seems to be a bug.
take care
psor
Compiled with Python version 2.5.
Checking for installed Python... got it!
BLENDIGO v1.0.5b
Windows-platform: win32 os.sep: \
indigo path: X:\Indigo\indigo_v1.0.6\indigo.exe
scene.getActiveObject() deprecated!
use scene.objects.active instead
INDIGO MATERIAL PREVIEW EXPORT
File "<string>", line 2977, in buttonEvt
File "<string>", line 1252, in materialButtonEvt
File "<string>", line 2125, in exportMatPreview
NameError: global name 'exportMaterial' is not defined
take care
psor
@psor:
That will be simplified a lot, in the future
http://www.blendernation.com/2008/02/18 ... f-blender/
Hey, just thought I'd file a bug report...
If you try to set the camera focus to "Selected" (object) when there isn't anything selected, it gives a python error and the script quits.
From the status window:
Yeah, yeah, I should've made sure something was selected first, but whatever.
BLENDIGO v1.0.5b
indigo path: C:\bin\Blender\__Indigo\indigo_v1.0.6\indigo.exe
File "<string>", line 2947, in buttonEvt
File "<string>", line 2987, in setFocus
IndexError: list index out of rangeFrom uncyclopedia.org, on "Elephant's Dream":
