A natural situation
Re: A natural situation
Ok, I made a test the other day, with this parameters, but I'm not sure about the results, if you look at the sky colors ( or the color should be right if longer render time maybe I don't know, I had no more time to test this )
Hi Onizuka. Sorry for your scene.
The v4.0.38 still loose power with time, decreasing the samples/pixel of the scene, but not so much.
Hi Jay-ko.
I can´t understand the joke, sorry.
But if there is something wrong with the picture just tell me to do it better in the future...
I´m not very good with the color...
Another bidirectonal path tracing test over earth simulation with atmosphere. Sample quality is not very good but run on esteroides (8M samples/s in windows 8.1 and more than 10.5M samples/s in windows 10). Physical aperture difraction. There is a defect on the water bump.
The silver sphere has 1 km radius, so the islands are giant (I put this reference later). A little disaster but here goes.
Just realized that bidirectional mode works without the need of any trick for earth simulation (not for a patch !!).
Indigo v4.0.41 starts to sample but freezes at minute two.
Bidirectional metropolis because I want to capture the reflection of the physical aperture difraction. I must to compare it with a simple metro with post-pro aperture...
Still this defect on the bump, I don´t know why.
With circular aperture the speed is normal (867 k samples/s) and the samples are of a better quality...
Cool.
Is the water a bump texture, or a shader?
A shader. Really strange...
The oceans mesh is highly poligonizated and has two subdivision with smoth on.
Nicole Kidman
Looks nice!
Thanks for the tip!
tell me please where you can download Indigo scenes examples? Exterior an Interior
Thanks for the tip!
So many thanks, Thread closed I miss this...
P.D. you can smell the road and pick up some examples of all.
Hi Yonosy!yonosoy wrote: ↑Mon Aug 01, 2016 8:08 amJust realized that bidirectional mode works without the need of any trick for earth simulation (not for a patch !!).
Can you tell me how I can achieve this in Sketchup, Please
Also If you can help me to achieve this effect in Sketchup I will be grateful to youyonosoy wrote: ↑Tue Oct 20, 2015 10:26 pmWorking around with IES I realized that is not possible to simply apply the IES profile to the polygons of a bulb.
IES expetcs a simple polygonal plane. Almost here the light pattern of the IES is lighting from every polygon of the bulb with odd results.
Then I substitute some bulbs per polygons plane and the mie_cumulus phase per uniform and seems very correct.
Next to come some mist in a forest.
