Normal problem :p
7 posts • Page 1 of 1
tibicen
Normal problem :p
Post by tibicen » Sun Feb 03, 2008 9:40 am
When i export indigo tells :
ModelLoadingStreamHandlerExep: Normal was not unit length (in element "mesh" around line 461092
How can i find this mesh? How can i fix it to render?
Anthony
Post by Anthony » Sun Feb 03, 2008 9:59 am
Try the outliner to find objects... But yeah i have no idea what that means...
tibicen
Post by tibicen » Sun Feb 03, 2008 10:06 am
i found them but i can't tell anything. i'd recalulated normals but still doesnt work...
Post by Kram1032 » Sun Feb 03, 2008 10:57 am
I'm not sure, but try to select your whole scene and press Ctrl+A :)
kwez
Post by kwez » Tue Feb 05, 2008 6:05 am
I had a problem like that recently,
in the IGS file, a bunch of normals where 0,0,0.
The way I fixed it .... redid the operations I had done that caused those results !!
I was carefull the 2nd time to do extrude, etc, one face at a time and with the object rotated so that the face I was working on was 'flat on screen',
it did work that time ... !!??
It might be interesting to try to reproduce the problem in a simple scene,
to figure out what NOT to do !!
I know this is not very helpfull, but I still thought it ould help :oops: :D
tibicen
Post by tibicen » Wed Feb 13, 2008 7:41 am
Another problem:
objects does not have geometry data? while exporting...
Post by Kram1032 » Wed Feb 13, 2008 8:14 am
sounds like objects with no geometry at all ;)
use the outliner to find and eliminate them...
