problem with SSS and light
13 posts • Page 1 of 1
freaks
Post by freaks » Wed Feb 06, 2008 1:12 pm
hello i try to illuminate a big transparent egg. I have some problems, SSS give me a black object and light illuminate the outside of the object instead of inside .
this is my blend file, i used blendigo to export igs file
http://www.noog.fr/forum/egg.blend
thank you for your advice
SimonLarsen
Post by SimonLarsen » Wed Feb 06, 2008 7:28 pm
Well, first of all, your mesh needs some thickness and correct normals.
Also, your egg's material, is a diffuse transmitter.
To make it transparent, it must be a specular material.
Your old SSS material is still in the blend, at the problems seems to be the high RGB-gain (the value below Absorp type).
100 i quite a lot.
I hope it helps you. ^^
aleksandera
Post by aleksandera » Wed Feb 06, 2008 9:36 pm
Yap, and than you'll maby get something like this:
Post by Kram1032 » Thu Feb 07, 2008 3:29 am
actually, it's interesting in both ways :)
aleksandera
Post by aleksandera » Thu Feb 07, 2008 3:44 am
freaks, I can send you the modified blend file back if you wish.
aleksandera
Post by aleksandera » Thu Feb 07, 2008 4:09 am
BTW why dont you use blended materials? The sss renders fer ever
and I see you have only one thread.
First one 5 hours
Second one 5 min
(Core duo Quad)
Post by BbB » Thu Feb 07, 2008 4:27 am
There's definitely no need for SSS to do this. Blend a phong and a diffuse transmitter with the same colours. It'll render in a fraction of the time and will look nicer.
aleksandera
Post by aleksandera » Thu Feb 07, 2008 4:49 am
Well yes. I did this in some way.
Hower here is the blend file. Hope it comes handy to someone.
egg1.rar
(81.64 KiB) Downloaded 294 times
freaks
Post by freaks » Thu Feb 07, 2008 5:43 am
ouhaou !!!!! thank you !
but i changed the original object and tried a new version of the egg, but i thin i have problems with normals. What is the manipulation to correct this ?
http://www.noog.fr/forum/egg2.blend
aleksandera
Post by aleksandera » Thu Feb 07, 2008 7:15 am
Select all faces and press Ctrl - n, recalculate the verticles outside.
Regards
Aleksander
freaks
Post by freaks » Thu Feb 07, 2008 7:33 am
ok it's perfect ! thks
freaks
Post by freaks » Thu Feb 07, 2008 9:39 pm
i have another question about lighting
but in one case i have some interesting with light inside the object but outside it's too dark, and in another picture i have something good outside, but eggs are no more illuminated in this case
so how can i merge the two aspects ?
the two pictures
aleksandera
Post by aleksandera » Fri Feb 08, 2008 12:20 am
I think here helps nothing else than experimenting with diferent values on the lights-emitters that are inside the egs, and those which are iluminating the whole scene.
Keep it up!
Aleksander
Users browsing this forum: No registered users and 67 guests
