HI; I big problem.
I have to draw in a houe the electic circuits
(you know..the electric wire from the bulb to the switch)
but not using a small extruded circle along a line, (to difficult in a render)
Like in the exemple.. making simple line not a pipe
thanks a lot
How to draw (and render) Power Lines (circuits)
- impianto solare.jpg (24.12 KiB) Viewed 2975 times
you can use the spin functions to rotate around edges
Well... as thin as an edge... - there's one problem:
Indigo actually renders edges... But edges are infinitely thin. So there's no chance that they'd ever get hit by a light ray
No way, you'd ever see them.
There's one last way: you could extrude the edges *after* shaping them correctly
This way, you could get both flat planes or cables with extremely thin volume.
The best way still is to directly use tubes and go around edges with the spin function in my opinion
Edit: Oh wait, nonsense, sorry: You're using SketchUp... I dunno, how to do it, there, if at all...
Draw the line (wire), than create a very small circle at one end of the line, than select all of the line and use the Follow Me tool. It will make all the corners and everything, super easy, one of my favorite tools in skp!
