Indigo 1.0.5
The reason is simple: if I want to extend the filter types to take extra parameters, then it's good if they're XML elements and not strings.psor wrote:That's exactly how it works! Now you got it!
Of course you could ask right now, why he did not do it like this ...
<splat_filter>mn_cubic</splat_filter>... but then he probably would say:Code: Select all
<downsize_filter>mn_cubic</downsize_filter>
So take it like ...
take care
psor
Thanx for explanation Nik!
btw. you broke the v1.0.5 ... look into the sun! "Overflow" bug ...
happens with aperture_diffraction enabled!
And something is wrong with the way the obstacle map is working.
I'll prepare a bug report later ... first I need some hours sleep. ;o))
take care
psor
take care
psor
"The sleeper must awaken"
rendering
i've been trying to use indigo to render one of my projects from sketchup and the whole thing is taking so much time to render and the wuality is still a bit blury....is there something i am missing here? some kind of setting i am not using?
- im1205465439.png (1.73 MiB) Viewed 5330 times
You're missing the unbiasedness of Indigo
Unbased renderers will always take long to render images. The higher the resolution, the slower. The bigger the scene (dimension-wise) the slower. The more polygons (at least, if you don't have enough RAM), the slower. The more complicated materials (in this scene especially the quite pure white walls, etc...) the slower
And maybe, the blurriness comes from the filter...
