My Knife ***Rebuilt***
- Phr0stByte
Some of you may have seen the one I did previously in Blender. This one is a more complex/accurate version. Also, I would like to point out that Indigo's aperture_diffraction provided a nice, natural glare on this one. This image has no post-pro at all.
[EDIT] Added the post-pro version (top)...
- im1200766965[800x640].png (399.49 KiB) Viewed 3294 times
- im1200766965.png (500.18 KiB) Viewed 3436 times
- Phr0stByte
More than clean enough for me. Just go over it with a decent noise filter (NoiseNinja for example) and it should be perfectly clean. Works wonders for me, and it should have no problem at all with that noise.
I like the modelling and glare and everything, nice composition. The background works well too
- Phr0stByte
- Phr0stByte
Thanx Kram. This is just a downsampled version for the forum (800x640). Original size is 1280x1024 - the noise is much more apparent on that one, of course. Also, I have done a little more testing, and found that the aperture_diffraction seems to be attracted to nk mats the most - especially cr.nk
Haven't used NeatImage, so I don't know. You will need to do some tweaking to get the best results. What I do is I create a duplicate layer and apply the noise filter to the duplicate. Mostly I don't denoise the luminance channel as much as the colour channel, to keep at least a bit of grain (I don't like images that are perfectly smooth, looks unrealistic somehow). But I only "like" luminance grain, which is a bit like film grain. Anyway, NoiseNinja usually wants to sharpen the image at the same time, I would leave that away first though. Then you erase away the parts of the duplicate where you want to preserve detail, don't like the blurriness etc., you may also set the strength of the eraser to only lessen the effect of the denoising. At the end you may sharpen if you want.Phr0stByte wrote:kadajawi
Thanks! I have don't like noise filters, as they have always done away with the noise, but blurred the image somewhat. I usually use NeatImage Pro when I do use one. Is NoiseNinja better in that regard?
NoiseNinja saves me a lot of rendering time, I think it is very helpful.
Maybe you can show a crop of the noise?
Makes sense:
realistic metals cause realistic reflections, which causes realistic diffraction, I guess
So, under circumstances, every fairly realistic tabulated - spectrum or nk material should give a good refraction
You could try, just for testing, to convert that red to an nk-file, too and look if the diffraction looks different, then
- Phr0stByte
Added post-pro version - see above.
[Edit] And just for kicks, here is a Mental Ray image of the same scene. I wont even tell you how long THAT took... (39 min. 51 sec.) LOL
- swiss_army_knife_MR_800x640.png (263.86 KiB) Viewed 3267 times
- ViennaLinux
