Indigo Renderer 4.6.4 Release
easyarchitect
Re: Indigo Renderer 4.6.4 Release
Post by easyarchitect » Fri Sep 16, 2022 12:29 am
Found BUG in version 4.6.4 (not present in version 4.6.0) only in OpenCL mode
The background overwrites all (see attachments)
Not present in 4.6.4 (BiDir mode) or 4.6.0 (BiDir or OpenCL)
Looking at the number of samples/sec in the two cases, it's as if it doesn't render anything except the background....
A. Delle
Indigo 4.6.4 (Bidirectional Path trace - Sw Mode)
Indigo 4.6.4 (Path trace OpenCL)
Indigo 4.6.0 (Path trace OpenCL)
easyarchitect
Post by easyarchitect » Fri Sep 16, 2022 12:57 am
The same Project (Indigo 4.6.4) sometimes causes "Out of resource" error on my videocard (NVIDIA GeForce RTX 3060 Laptop GPU).
Error: Exception while advancing OpenCL PT on device 'NVIDIA GeForce RTX 3060 Laptop GPU': clEnqueueReadBuffer failed: CL_OUT_OF_RESOURCES
Indigo 4.6.0 renders correctly
( you can download the IGS project from here >>> https://we.tl/t-h9dPVcsJ3C )
Enrico
Post by Enrico » Tue Sep 20, 2022 3:48 am
A. Delle
I've the same problem...
Yiqin
Post by Yiqin » Wed Sep 21, 2022 2:22 am
Thanks for keeping it going Ono!
Post by Headroom » Sat Oct 01, 2022 1:28 pm
Not sure its the exporter or Indigo, but something seems horribly broken when GPU rendering on my system:
Another older scene renders fine, yet another one after the first "flash" of an image, it only renders the environment HDRI.
mpro31
Post by mpro31 » Sat Oct 01, 2022 9:45 pm
Thanks for this update, I'm glad Indigo is alive. Please keep that way, subscription based if needed.
Post by OnoSendai » Tue Oct 04, 2022 1:19 am
Yeah have found + fixed this bug, will make new build soon.
Post by Headroom » Wed Oct 05, 2022 3:03 am
@OnoSendai Awesome, thank you!
In the meantime the updated Blendigo also works with 4.6.9.
wob
Post by wob » Fri Oct 07, 2022 1:58 pm
hi, very strange behaviour: the same scene, the same rig (5x 2070/2060s) but:
- cindigo 4.4.13 - 660 samples / sec
- indigo standalone 4.6.4 (and 4.6.0 too) - 550 samples / sec (exported from cinema 4d thru cindigo 4.4.13)
nvidia driver 517.48
gpu utilization of cindigo (left) and standalone (right), the same scene:
p.s. but it has the same samples/sec with single primary GPU - cindigo and standalone (2 gpus or more - different)
test.zip
(53.58 KiB) Downloaded 1033 times
Zalevskiy
Post by Zalevskiy » Sun Oct 16, 2022 12:35 pm
https://www.indigorenderer.com/materials/materials/273
This material crash
https://www.indigorenderer.com/materials/materials/1337
This material very slow speed render mode BiMtl
Sometimes (Random) it helps to switch the parameter _ Number of values: 301 fast double click to 299 and to back 301
Proof video bug 300 to 301 black dots
bug_light_indigo.zip
(4.02 MiB) Downloaded 1139 times
BrianB
Post by BrianB » Mon Oct 17, 2022 5:36 pm
This is very encouraging. I am looking for the best alternative to Maxwell render and Indigo seems a good fit.
Some things that are important for me to switch or to add Indigo alongside Maxwell....
The most important for now is using NK/IOR files seems more difficult than I would like. I don't understand why there is not a standard file requester to load the data, or why adding additional data requires overwriting NK files in the application folder. More detailed documentation about this would be useful.
Clear signs of development activity is important and a big part of why I am looking for alternatives to Maxwell Render.
ErichBoehm
Post by ErichBoehm » Wed Oct 19, 2022 4:54 am
Unusable. Is this being checked for bugs before its put out there? Within 2 minutes of trying to use it, something falls apart.
Yiqin
Post by Yiqin » Thu Oct 20, 2022 12:08 am
@ErichBoehm
This is a beta release for those who wish to help the developer find and fix bugs and try out newer features. For the latest official stable release you should go here:
https://www.indigorenderer.com/download-indigo-renderer
Either way your comment doesn't do anything to help anyone, yourself included, solve whatever issues you're facing. There are some great, and very talented, people on the forum that might be able to help if they knew what the issue is. Also the developer can't fix bugs he's not got any actionable info on.
Post by pixie » Thu Oct 20, 2022 1:09 am
It is the best, no doubt about it!
wob
Post by wob » Thu Oct 20, 2022 2:28 am
4.6.0 beta is usable
Users browsing this forum: No registered users and 67 guests
