i dont have access to a mac...
Cindigo 1.0 - beta 2
- pixie
fused wrote:no, sry
Hey fused... Maxon just released the 10.5 C++ SDK.
I don't know if this is interesting for you, and also have no clue about 10 vs 10.5 compatibility, but here is the link:
http://www.maxon.net/pages/support/plug ... ads_d.html
BTW:
An Idea why Cindigo needs the Quicktime PlugIn or refuses to load, would be maybe the PNG Icons you are using...
PNG Support in C4D is only available by having Quicktime installed, otherwise PNG Textures wont work too.
just an Idea
BTW:
just an Idea
Okay, nothing to contribute here, but I just had some free time to install the new exporter and Indigo after not using it for a looong time, and I have to say that it is totally awesome ! Great integration, works like a charm. I didn´t get to test it on really complex scenes but what I can see I really like !!!
Michael
Michael
uploading the scene would be useful..
what you can check:
-if you use cm as unit in c4d, you have to set the global scale multiplier to 0.01 in cindigo.
-copy the missing object to a new scene and try again. (if it was made with a previous version of cindigo, and you installed a more recent one, this can lead to problems..)
what you can check:
I have used meters as unit, but setting to cm doesn't help either, doesn't seem to change anything.
I've tried copying the missing objects to a new scene, same problem. I will attach the new scene (renders quicker etc.).
Here is the new scene, with textures (without textures the rendering looks different... more stuff is working, but it's still weird).
http://home.arcor.de/kadajawi/3D/Lautsprecher.rar (was a bit too big for an attachment here).
Azrael Crusader
Hy, I've got the idea to try indigo together with cinema. I've downloaded Cindigo, the newest Quicktime and of course Indigo. I renamed the file, because I'm working with Cinema 10 and copied into the plug-in folder and... nothing...
I don't see any Tags, export functions or something else... What am I doing wrong?
Regards
Azrael
Regards
Azrael
Hm, but I didn't see any difference between 1 cinema cm and 1 cinema meter, they should be of different brightness I thought. Nevermind, I will leave it at 0,1
Thanks alot! And I will change the wood
@Azrael: Is it in the plugins directory? On my computer it looks like C:\Program Files\MAXON\CINEMA 4D R10\plugins\Cindigo 1.0.2
If you look under Plug-ins on the C4D menu there should be a Cindigo 1.0.2 thing.
Azrael Crusader
