h
yonosoy
Re: h
Post by yonosoy » Tue Sep 06, 2022 10:08 pm
Diaphragm too narrow gives bright spots in the center of the image. By defect, this cam focus at a few centimeters of distance. In order to focus at some meters, I setup a very narrow diaphragm. Lately, since I use an eight blade diaphragm well defined instead of a cilinder with a controlled "hole", things, programs advance, now is possible to setup a coating ten times thicker than must be (instead of the 100 thicker coating than was setuped the last years), less dispersion, a correct spherical distorsion, less lost of focus in the peripherial, ... better.
HOUDINI APPRENTICE 19.5.303, CINEMA 4D 23, INDIGO RENDERER 4.6.2
Here goes the cinema scene, the materials and the houdini file.
Canon_24mm.rar
(3.18 MiB) Downloaded 852 times
yonosoy
Re: h
Post by yonosoy » Sat Oct 01, 2022 8:59 pm
18 h.
yonosoy
Re: h
Post by yonosoy » Sat Oct 01, 2022 11:54 pm
Less than one hour.
Diaphragm very narrow. Pretty good. It can be better. In a days I post the last version of this camera. A lot of changes with the previous.
yonosoy
Re: h
Post by yonosoy » Sun Oct 02, 2022 1:47 am
1 hour, only the flash. The capture simulation illumination introduces a lot of problems actually. Still a little brights with diaphragm that gone with time, but still some ghosts...
yonosoy
Re: h
Post by yonosoy » Sat Oct 29, 2022 7:22 am
8:33, 2450 spp.
No se porqué los árboles sólo se expresan en una parte del terreno (tenga la orientación de cámara que tenga). Sin embargo con la hierba se comporta bien.
Lo de siempre, un esbozo. Tres variaciones de un árbol construído por procedimiento con Houdini (hay que instalar Labs FX. o algo así), una instancia de hierba ( ¿no parecen hortalizas en un huerto? ). Con unas cuantas variaciones más, flores, pájaros...
Mie cumulus necesitaría un repaso. Si utilizas esferas no perfectas está bien incluso en path tracing (esta es bidireccional path tracing). Siguen saliendo bandas purpura-verdes si las nubes no son suficientemente compactas, también a veces si lo son.
arbol_01.rar
(74.97 KiB) Downloaded 858 times
yonosoy
Re: h
Post by yonosoy » Tue Nov 08, 2022 1:22 am
31 h, 1273 spp.
Ctz´n se atrevió a soñar. Lo único que te ofrezco son cinco esferas puestas en orden. Investiga si quieres. Es un fantástico sueño...
Si quieres más velocidad rebaja el parámetro "scattering" y prueba a subir un poco el "maximum coefficient of extinction". Ten en cuenta el parámetro "absorption", y el parámetro "offset" en ambos campos del medio.
nubes.rar
(3.6 MiB) Downloaded 873 times
yonosoy
Re: h
Post by yonosoy » Fri Nov 11, 2022 10:36 pm
2 h, 200 spp.
Vamos a llamar a ésta "tattoo".
Es curiosa la complejidad de los "glitches" que genera indigo ...
Los lacrimales están demasiado rojos, demasiado brillantes, ... Por lo demás, suficiente; no pasearé este carácter más.
yonosoy
Re: h
Post by yonosoy » Fri Feb 24, 2023 9:32 am
yonosoy
Re: h
Post by yonosoy » Fri Feb 24, 2023 2:04 pm
yonosoy
Re: h
Post by yonosoy » Fri Feb 24, 2023 2:27 pm
spheres
yonosoy
Re: h
Post by yonosoy » Fri Feb 24, 2023 2:38 pm
yonosoy
Re: h
Post by yonosoy » Fri Feb 24, 2023 2:39 pm
tambien soy artista, pero necesito esto asi :) Animo y Modales ...
yonosoy
Re: h
Post by yonosoy » Fri Feb 24, 2023 2:43 pm
no lo puedo hacer mejor, lo siento, pero esro es genial
yonosoy
Re: h
Post by yonosoy » Fri Feb 24, 2023 2:47 pm
tengo ganas de ver como continua cclors... querido, espero tu primera obra autonoma.
yonosoy
Re: h
Post by yonosoy » Fri Feb 24, 2023 4:26 pm
Users browsing this forum: No registered users and 181 guests
