dougal2
by dougal2 » Wed Jan 16, 2008 1:01 pm
Here is a Windows 64 bit build of Violet.
Built and tested on Vista 64 bit.
The installer wants to install to \Program Files(x86)\* by default, but this is a 64bit build, just change the install dir - I couldn't figure out how to in VS2005 yet.
EDIT: despite the .zip name, this is actually 0.1.3 as far as I can tell. The About dialog will tell you that it's 64-bit (this is the only change to the available source that I made).
- VioletSetup-0.1.2x64-noredist.zip
- (2.53 MiB) Downloaded 2001 times
by Zom-B » Wed Jan 16, 2008 2:08 pm
Thanks for your afford dougal... runs fine here on Vista 64 bit.
But I can't have the 32 bit & 64 bit version on my system installed at the same time, so comparing both speed vise isn't easy...
dougal2
by dougal2 » Thu Jan 17, 2008 10:08 am
I've just run a test, and if anything it appears to be a little slower
average of 3 runs, diffraction limited bloom with all default settings on an 1280x720 IGI:
32bit - 2.756 sec
64bit - 3.122 sec
