http://indigomaterials.uk.to/ LAUNCH :)
Ah, yes Opera....
I've spent hours trying to make the javascript libraries work with Opera. They simply don't. The site won't work with Opera for the time being.
For now, use Firefox.
At some point I will change the interface to use a different script (this time of my own making), which I will design to work with Opera too.
Hey dougal2,
I just tried to create a glossy transparent IGM file online. It worked fine but I am concerned with how mediums are being handled. I assume you plan on improving this. Right now, you have to select a medium from a drop-down list (which will eventually become enormous...). However, once you select the medium, you cannot check the attributes of the medium.
Maybe it would be best to combine the medium attributes with the material attributes in order to simplify this.
I am sure you are already on top of this but I just thought I'd mention it anyway. Again...VERY impressed with your work! (Where are all ther material uploads?? BbB?? drB?? Hello?!
Whaat:
I have in fact just separated out the mediums into their own table...
For the time being this means that medium editing is broken, but it will get fixed in due course. *
This also means that mediums for materials can have the same name as the material - exactly how blendigo exports them.
(I don't particularly agree that there should be multiple <name> elements in a scene with the same value, but my opinion doesn't matter in this case).
The medium chooser in specular/gloosy transparent will also become an auto-complete search box like the texture names.
* the navigation of the site may change at around the same time to be a bit easier, and compatible with Opera. It's all part of a bigger plan
- drBouvierLeduc
Hi Dougal2,
First thanks for your database, that's a great idea and it works very well (though for the moment I didn't upload anything yet...).
However, I think you could improve the homepage, I think these 2 things are quite important to make it a little bit more usable and practical :
- Rather than a long text field, I'd rather see the "latest materials" uploaded, so you can see if there's anything new in a sight
- Also put the different categories more visible, just next to the latest materials, with a generic picture for instance.
- Oh, and one last thing : maybe you should provide a downloadable material scene of your own, even if it's not the "official" one, so there's not billions of different preview images (I've put the link in the loging aera, in my mockup).
As you can see I've made a mockup of what I'm talking.
Tell me what you think, I guess with those small changes your database can become more popular.
And again, thanks for that long awaited database.
- mockup
- database.jpg (93.3 KiB) Viewed 4132 times
Heya mate, I've got a problem with uploading .IGM files to your DB.
error:
The .IGM i tried to upload looks like that ...
I did already try to remove the first line, the version tag but that was not
causing the errors. So you might wanna have a quick look at it. I would
really love to start uploading some stuff, but right now I just can't.
nb: I've got a request for you. Could you please make it possible
to upload more files (TEX/IGM/PIGM) at once. It's getting tedious to upload
files, file by file.
Thanx in advance! And thanx for your work and the service you offer.
edit: Hmm, it could be the names of the material, I can't even
import them back into Maxigo. I'll check that out ...
take care
psor
error:
A PHP Error was encountered
Severity: Notice
Message: Undefined index: SCENEDATA
Filename: libraries/Igm_parser.php
Line Number: 60
Severity: Warning
Message: Invalid argument supplied for foreach()
Line Number: 41
Severity: Notice
Message: Undefined variable: matStatus
Filename: controllers/upload.php
Line Number: 253
<!-- Exported From Maxigo 1.03.5 -->
<materialdata>
<version>1.03</version>
<material>
<name>Flower.Anther_brownish_diff.transmitter-tdiff</name>
<diffuse>
<albedo_spectrum>
<rgb>
<rgb>0.588235 0.588235 0.588235</rgb>
<gamma>2.2</gamma>
</rgb>
</albedo_spectrum>
</diffuse>
</material>
<material>
<name>Flower.Anther_brownish_diff.transmitter-transmitter</name>
<diffuse_transmitter>
<albedo_spectrum>
<rgb>
<rgb>0.435294 0.247059 0.247059</rgb>
<gamma>2.2</gamma>
</rgb>
</albedo_spectrum>
</diffuse_transmitter>
</material>
<material>
<name>Flower.Anther_brownish_diff.transmitter</name>
<blend>
<a_name>Flower.Anther_brownish_diff.transmitter-tdiff</a_name>
<b_name>Flower.Anther_brownish_diff.transmitter-transmitter</b_name>
<blend_factor>0.85</blend_factor>
</blend>
</material>
<material>
<name>Flower.Anther_brownish_diffuse</name>
<diffuse>
<albedo_spectrum>
<rgb>
<rgb>0.443137 0.160784 0.121569</rgb>
<gamma>2.2</gamma>
</rgb>
</albedo_spectrum>
</diffuse>
</material>
<material>
<name>Flower.Anther_brownish</name>
<blend>
<a_name>Flower.Anther_brownish_diffuse</a_name>
<b_name>Flower.Anther_brownish_diff.transmitter</b_name>
<blend_factor>0.5</blend_factor>
</blend>
</material>
</materialdata>
take care
psor
"The sleeper must awaken"
your IGM contains no scenedata element the correct XML is
<?xml version="1.0"?>
<scenedata>
<medium>
</medium>
<material>
</material>
</scenedata>
Well...
yeah, it includes:
That's it. No material in between...
yeah, it includes:
<scenedata>
</scenedata>Thanx Doug, I didn't pay enough attention. It seems suvakas is cooking
his own little soup. I'll let him know that he has to take care of that.
And regarding the .PIGM ... I'll try that!
edit: Please have a look at the attached PIGM. I'd like to know
what's wrong this time ...
note: You've to rename it, I can't attach PIGMs at the forum.
edit2: How to delete all the "crap" that shows up in my material list?
edit3: Ohhh f*ck, found it! Could you please add checkboxes to
avoid deleting materials file by file ... this is horrable! Sorry for ranting!
take care
psor
take care
psor
- psors_flower.zip
- IGM includes the following IGM files:
- Flower_Anther_01.igm
- Flower_Filament_01.igm
- Flower_Leaves_01.igm
- Flower_Petals_01.igm - (1.86 KiB) Downloaded 164 times
