Studio Lamp
Studio Lamp
Here is an idea for a basic studio light for indigo that I came up with after perusing google images a few days ago. It works quite well with linear tonemapping set to 1 (
) and is also really easy to tune shadows by scaling the lamp size or changing the blend amount of the diffuse cover.
- lamp_size.jpg (45.43 KiB) Viewed 10204 times
- lamps_afar.jpg (125.17 KiB) Viewed 10204 times
- lamp_closeup.jpg (41.3 KiB) Viewed 10204 times
Some simple pics using the light.
(Please excuse my noise)
- screwdriver_sphere.jpg (94.88 KiB) Viewed 10197 times
- balls.jpg (158.19 KiB) Viewed 10197 times
The .blend file didn't attach earlier
, so here it is in a zip
- studio_lamp.zip
- (152.36 KiB) Downloaded 251 times
I just figure whats the point of using a realistic renderer if you don't use realistic lights (or close to)
Here's another experiment - In the 1st image I replaced the material of the diffuse cover with the light emitter material so it's now a typical flat plane emitter while the 2nd image uses the studio light.
The 'ball' subject is 2m wide and the light intensity is that of a 'typical' 575w studio lamp. Also both are unprocessed (linear tonemapping=1) and there was virtually no speed difference in rendering at all !
- studiolight.jpg (98.13 KiB) Viewed 10033 times
- flat_meshlight.jpg (69.91 KiB) Viewed 10033 times
not really...
this technique works like a diffuser.
IES actually do the exact opposite:
The light of any lightsource in Indigo usually emits perfectly uniform(/diffuse) over the light source's surface.
IES files include data, in which direction how much light gets emitted. So, it makes the light less uniform or less diffuse
