Hasselblad 503cwd
noyb
Hasselblad 503cwd
Post by noyb » Mon Dec 31, 2007 2:21 pm
This is a re-render of a quick model that I did with mentalray several months ago. I figured a render of a camera should be more photo realistic.
Pretty far from finished - lots of minor issues to fix (smoothing & model export issues - the logo is out of place for some reason)
The bump on the camera body needs much more work
I'm not sure where I want to go with this - perhaps a scene of a photo studio...
Here's my progress so far - 1.0.3 - no exporter.
<2h on single 1.8
jeffr
Post by jeffr » Mon Dec 31, 2007 2:56 pm
?-what do you mean all by hand with no exporter ?
noyb
Post by noyb » Mon Dec 31, 2007 5:56 pm
The xml setup - materials/camera and such. I didn't model it by xml code if that's what you're thinking - model is a 3ds file.
joegiampaoli
Post by joegiampaoli » Mon Dec 31, 2007 6:13 pm
aww common!
Anyone can model that by XML, as simple as a cube :P
Anyway, nice render, I love Hasselblads, best f***ing camera in the world
Maybe wanna try lowering your lights a bit?
Joe Giampaoli
My Indigo Gallery
noyb
Post by noyb » Mon Dec 31, 2007 6:20 pm
My light setup is temporary, I'm just trying to work out model and texture issues at the moment - I'll lower the tonemapping a bit on the next one
Tato
Post by Tato » Tue Jan 01, 2008 10:33 pm
try to put it in scene similar to those in their catalog ;-) nice modeling
noyb
Post by noyb » Wed Jan 02, 2008 8:06 am
Thanks for the comments
Still some things to do to this before I start working on the studio scene to show off the digital back...
-The Hasselblad and 503cwd logos are not visible (to be honest, I'm not sure if they are even there - you can see that the logo is offset in the first render, no idea why)
-The lighting causes the reflections to be a bit too high contrast - I'll probably add a white(ish) plane for the chrome to reflect to bring down the white/black contrast
-The bump still isn't even close (this is the first time I've used bump in indigo)
Any tips (especially with the bump on the camera body) are greatly appreciated.
Update: 1.0.3 @ 19h on single 1.8
noyb
Post by noyb » Wed Jan 02, 2008 8:12 am
This is the one that I did with mentalray for a comparison:
MentalRay version
Post by Kram1032 » Wed Jan 02, 2008 9:21 am
I actually like the highlights!
For the bumpmap: which b-value are you using? try to divide it by 10, as a starting point...
noyb
Post by noyb » Sun Jan 06, 2008 10:46 am
Bump is a bit better - logo still isn't showing up though
Used camera tonemapping on this one
~13h
dougal2
Post by dougal2 » Sun Jan 06, 2008 10:48 am
You're on Maya, right ?
Objects that don't display or are in the wrong place are usually to do with locked transforms, or complex parenting/constraint setups.
Try unlocking, and exporting again.
Looks really fantastic, BTW :)
My dad has one of these with the digital back... very very nice camera
Post by Kram1032 » Sun Jan 06, 2008 10:50 am
looks great! Much better bump :) maybe even weaker?
dougal2
Post by dougal2 » Sun Jan 06, 2008 10:51 am
bump looks ok here, the cameras are quite bumpy.
Phr0stByte
Post by Phr0stByte » Sun Jan 06, 2008 11:47 am
noyb
I actually really like the MR version... Test3 is also nice, the the red writing on the lens is quite "hot" or saturated.
noyb
Post by noyb » Sun Jan 06, 2008 2:02 pm
Thanks for the comments :wink: (couldn't find an appropriate emoticon)
dougal2 wrote:You're on Maya, right ?
Actually, I use Autodesk Inventor and 3ds max.
I shouldn't have any constraints or anything applied to the mesh, I'll do some experimenting and see what happens.
Does your dad have the 503cwd or another in the 500 series. I've only seen one of these (other than pics on the net) - I saw it and went home to model one :).
I've done the digital back too; after I finish this, I'll try a scene like the brochure.
I think you're right Phr0stByte, I need to add more green to the text.
Perhaps I'll try a different background and see if it comes out better.
Oh, and thanks for the help on the bump Kram1032
