I need some helps(Update:06.Feb,2008)
Xman
Post by Xman » Tue Dec 25, 2007 4:18 am
Hello everyone,
I am use C4D 10.11 and cindigo 1.0b2.
Now can't work, I don't know the problem come from where, have you already met such situation? hope can tell me right method.
Thank everyone.
--greeting & Good Luck
Post by fused » Tue Dec 25, 2007 4:23 am
this happens if you have lots of unused points. use functions->optimize.
you seem to define the material of the inside of the cups more than once. you only have to denfine it once in a material tag somewhere in the scene and can use it as on any model you want.
nice to see that someone is actually using my exporter! :D
Xman
Post by Xman » Tue Dec 25, 2007 4:47 am
Hello fused,
Looks, BE my method problem perhaps, but I don't know how do is right.
This's a different scene in here, it owns a same problem.
please,you test it.
Thanks.........
--greeting & Good Luck--
Mp2.zip
problem scene
(1.33 MiB) Downloaded 418 times
Post by fused » Tue Dec 25, 2007 9:24 am
ok, i found the problem.
try deleting the normal-tag!
Marcofly
Post by Marcofly » Tue Dec 25, 2007 11:09 am
yes, the normals tag always gives this warning message, although i haven't noticed other than a longer warm-up..
BTW: merry Christmas, Yves!! :D
Xman
Post by Xman » Tue Dec 25, 2007 8:58 pm
Thank you-all,
Fused, can you let the normal-tag and Cindigo cooperate work?
Because no this normal-tag model will the not smoothness.
merry Christmas and have nice day :D
Marcofly
Post by Marcofly » Tue Dec 25, 2007 11:03 pm
delete the normal tag, and check that a phong-tag is applied to the object.
add a light and render it in Cinema4D: if it still looks not smooth, then it's a geometry problem, and you have either to subdivide it, or import it again in cinema, using a .obj file, not a .3ds!!!
Xman
Post by Xman » Wed Dec 26, 2007 12:54 am
Sorry,I think to need very much to cooperate with the normal-tag.
model is make by the Pro/ENGINEER(Industry design-software), export for the OBJ,no 3ds.And the OBJ can work very goodly in the C4D.
Example: Vary for C4D, Fryrender,Maxwell(Only at 1.6 is nice).
They can very nice cooperate work with the normal-tag.
So,I think the Cindigo same can. :)
You can see nether example:
Marcofly
Post by Marcofly » Wed Dec 26, 2007 4:36 am
upload the file (just one green object)
Post by Zom-B » Wed Dec 26, 2007 5:08 am
hmm...
I think by tweaking the Phong angle you could avoid this artifact very easy...
It seem your angle value is (way) to low!
Xman
Post by Xman » Wed Dec 26, 2007 5:23 am
Thank you
model,nwo have normal-tag.
thanks.........
Mp2 fro g.zip
(1.11 MiB) Downloaded 400 times
Post by Zom-B » Wed Dec 26, 2007 6:17 am
Hey Xman...
This Problem appears because your mesh isn't connected on the areas you have this issue.
You can also use instances in C4D and Indigo will use them too ;-)
Xman
Post by Xman » Wed Dec 26, 2007 4:35 pm
Hi ZomB,
Do you meaning the use of instances will be able to solve this problem?
I am sorry, you can tell you instances in where?
Thank you very much for the help.
Post by Zom-B » Thu Dec 27, 2007 1:56 am
Xman wrote:Hi ZomB,
Hey Xman...
No instancing wont fix your normal Problem!
You have to stitch the points shown in the post above together,
to get 1 mesh so the smoothing wount stop at this area...
You can also try something else!
The warning message from Indigo about normalization is no Bug!
At this point Indigo is doing the normalization, and it takes some time (about 5 minutes) and then Indigo starts to render... everything perfectly smooth!
Xman wrote:I am sorry, you can tell you instances in where?
By using Instancing for your green plastic thing you reduce the polys Indigo have to normalize, and it starts rendering faster...
atm you have 4 green things, that are totally the same... by having only 1 green thing, and instancing it 3 times, you'll save 3/4 of the polys and RAM + Time while rendering...
I hope this helps
Xman
Post by Xman » Thu Dec 27, 2007 2:49 am
Hi ZomB,
Thank you very very...I understand your meaning.The normal-tag and Cindigo can work very goodly now,Need to wait for some time only. :D
Hope hereafter can continue to get your help...thank you again :)
