I need some helps(Update:06.Feb,2008)
Hello everyone,
I am use C4D 10.11 and cindigo 1.0b2.
Now can't work, I don't know the problem come from where, have you already met such situation? hope can tell me right method.
Thank everyone.
--greeting & Good Luck
Thank everyone.
- 01.jpg (214.52 KiB) Viewed 18508 times
this happens if you have lots of unused points. use functions->optimize.
you seem to define the material of the inside of the cups more than once. you only have to denfine it once in a material tag somewhere in the scene and can use it as on any model you want.
nice to see that someone is actually using my exporter!
Hello fused,
Looks, BE my method problem perhaps, but I don't know how do is right.
This's a different scene in here, it owns a same problem.
please,you test it.
Thanks.........
--greeting & Good Luck--
please,you test it.
Thanks.........
- Mp2.zip
- problem scene
- (1.33 MiB) Downloaded 450 times
Sorry,I think to need very much to cooperate with the normal-tag.
model is make by the Pro/ENGINEER(Industry design-software), export for the OBJ,no 3ds.And the OBJ can work very goodly in the C4D.
Example: Vary for C4D, Fryrender,Maxwell(Only at 1.6 is nice).
They can very nice cooperate work with the normal-tag.
So,I think the Cindigo same can.
You can see nether example:
- 1-2.jpg (249.92 KiB) Viewed 18384 times
Thank you
model,nwo have normal-tag.
thanks.........
thanks.........
- Mp2 fro g.zip
- (1.11 MiB) Downloaded 433 times
Hey Xman...Xman wrote:Hi ZomB,
Do you meaning the use of instances will be able to solve this problem?
No instancing wont fix your normal Problem!
You have to stitch the points shown in the post above together,
to get 1 mesh so the smoothing wount stop at this area...
You can also try something else!
The warning message from Indigo about normalization is no Bug!
At this point Indigo is doing the normalization, and it takes some time (about 5 minutes) and then Indigo starts to render... everything perfectly smooth!
By using Instancing for your green plastic thing you reduce the polys Indigo have to normalize, and it starts rendering faster...Xman wrote:I am sorry, you can tell you instances in where?
atm you have 4 green things, that are totally the same... by having only 1 green thing, and instancing it 3 times, you'll save 3/4 of the polys and RAM + Time while rendering...
I hope this helps
Hi ZomB,
Thank you very very...I understand your meaning.The normal-tag and Cindigo can work very goodly now,Need to wait for some time only.
Hope hereafter can continue to get your help...thank you again
- im1198678687.jpg (64.61 KiB) Viewed 18268 times
Users browsing this forum: Majestic-12 [Bot] and 51 guests
