SkIndigo 1.0.4
SkIndigo 1.0.4
Use this version with Indigo 1.0.4.
You must download the new previews folder (SUpreviews) or change the name of your existing previews folder to 'SUpreviews' for this new version to work. As always, make sure this folder is in your Indigo directory (version 1.0.4)
INSTALLATION
1. Copy SkIndigo.rb into your SketchUp/Plugins directory
2. Copy the SkIndigo folder into your SketchUp/Plugins directory
3. Copy the SUpreviews folder into your Indigo directory
4. Remove any previous versions of SkIndigo from your SketchUp/Plugins directory
#Version 1.0.4
#Added: support for IES profiles
#Changed: changed previews folder name to SUpreviews to avoid conflicts with other exporters' preview scenes
#Added: aperture diffraction support
#Changed: made IGM import backwards compatible with older versions of Indigo (not fully tested)
#Added: Water preset (credit CoolColJ)
Aperture diffraction is currently enabled by default in order to facilitate testing. It will be disabled by default in the future.
I have re-written about 90% of the code since the last release so it is very likely that some features will be broken. I have not had the time to fully test this one. Please let me know of any bugs. Thanks!
UPDATED 19 Dec 07: Fixed 'Cancel Changes' button in Render Settings dialog
INSTALLATION
#Version 1.0.4
- SUpreviews.zip
- Previews folder (required download)
- (3.31 MiB) Downloaded 770 times
- SkIndigo.zip
- fixed Render Settings Cancel button
- (1.44 MiB) Downloaded 1243 times
Thanks Whaat! Just installed and found a couple issues.
When I hit "Cancel" in the Render Settings, I get a Runtime Error and it asks me if I want to debug. I said ok, and it took me to a Microsoft Editor to the Html line for the Cancel button.
Says in the Error box-
Line: 403
Error: Object Expected
Also, not really a bug I think, but when I open the Render Settings dialog box, if I don't make any changes and start hitting "Undo" it undo's what I did in the model, like hitting Ctrl-Z.
Anyways,
Looks great, hopefully I'll get some time soon to do some more renders to post.
Line: 403
Anyways,
It should be fixed now. Thanks.crojack wrote:When I hit "Cancel" in the Render Settings, I get a Runtime Error and it asks me if I want to debug. I said ok, and it took me to a Microsoft Editor to the Html line for the Cancel button.
Line: 403
It's not really a bug - more of a side-effectAlso, not really a bug I think, but when I open the Render Settings dialog box, if I don't make any changes and start hitting "Undo" it undo's what I did in the model, like hitting Ctrl-Z.
Pibuz/lorom,
I really need more information in order to fix this.
- does it only happen with material previews?
- does it happen with ALL preview models? (sphere, cube, etc.)
- does it ALWAYS happen every time you preview a material with a texture?
- does it ONLY happen with SkIndigo 1.0.4?
If you can find a case where it happens, please post the 'previewmats.igs' file that you will find in your 'SUpreviews' directory.
Thank you
Thank you
