skylight bug?
skylight bug?
I use blender 2.45, blendigo 0.9 and indigo_v09_test6. And when i render with sun light set up i got a black back ground. did i forget to do something?
Re: skylight bug?
Do you have any meshlights in your scene?dagobert wrote:I use blender 2.45, blendigo 0.9 and indigo_v09_test6. And when i render with sun light set up i got a black back ground. did i forget to do something?
What type of tonemapping do you use?
what i got
I got no mesh light in the scene. And nothing in tone map except Reinhard
my idea was that if you use physical sky and sun. it will create a sky according to the sun.
like in http://www.indigorenderer.com/blender_tut/#6a in the outdoor scene exemple. the background don t seem to be a picture in the background
It's basically for rendering in a vacuum. Indigo. In. Spaaaace!OnoSendai wrote:for the record,
"extra atmospheric" means out of the atmosphere. When it's turned on, attenuation and scattering in the atmosphere is turned off; the incident sun radiation is equivalent to that at the outer edge of the Earth's atmosphere.
I believe, you can use a specular material with an "atmospheric" medium to simulate an enclosed atmosphere, I haven't tested it, but it looks like SmartDen did.
SmartDen wrote:Extra atmospheric is needed to render 'space' pictures in real size like this
so you can switch off the atmospheric scattering and get a space vacuum.
If you render such big scenes, you should adapt the ray nudge and set it bigger. In this scene i used 0.001. Default is 0.0001
With atmosphere medium you can set up an atmosphere around a planet.
atmosphere atmosphere
ho do you set up an atmospherique paterial in blender?
^by clicking on extra atmospheric
Everything will be generated for you.
But the point indeed is, it's out of atmosphere.
This system can also render things inside atmosphere, but SmartDen didn't really add that option...
(Extra Atmospheric can be off. Then, it doesn't render the sky from outside but from inside. I'm not sure, if you then would see the moon, though... hum)
I forgot, that it works like that.
So, you'll have to hand-edit the igs and set extra atmospheric to false...
Users browsing this forum: DotBot [Bot] and 69 guests
