Skirmish
Vanessa07
Post by Vanessa07 » Mon Dec 10, 2007 9:50 pm
Very nice render, I love the B&W :oops:
Post by BbB » Mon Dec 10, 2007 9:53 pm
Merci Vanessa. The models are very rough in this last image. The one in the foreground doesn't have any subdivision. Just the lo-poly basemesh. And it shows!
Post by Kram1032 » Tue Dec 11, 2007 3:16 am
Looks great anyway!
Try to use it with 1.0.4, though :D you might get some unexpected good-looking bloom/glare :)
Post by BbB » Tue Dec 11, 2007 3:31 am
I'll probably upgrade tonight. The problem is I use Indigo on four different machines and I try to run the same version on all of them. But because I'm fundamentally lazy, it takes me a long time to go around the block and do the upgrade. I've even been known to unwittingly skip a version...
Post by CTZn » Tue Dec 11, 2007 5:01 am
Now the light scheme is interesting, very dramatic, element of tension between both subjects :D
I'd say: keep the old rig, at least partially. If I may ;)
Post by BbB » Tue Dec 11, 2007 7:51 am
Oops. 1.0.4 doesn't work for me. It goes fine for the 800x600 test render but crashes on me when I try 2400x1800. Running Vista... Oh well.
Post by Kram1032 » Tue Dec 11, 2007 8:11 am
What does it say?
Post by BbB » Tue Dec 11, 2007 8:45 am
Didn't take a note of it, silly me. Nothing specific if I remember well (I probably don't) more something to the effect that Indigo had to close unexpectedly and if I'd like to contact Microsoft about it. Happens just after warming up is over...
Post by Kram1032 » Tue Dec 11, 2007 10:25 am
Sounds like RAM problems...
Vista (if it's the 64bit version, which I suppose it to be) should allow up to 8TB Ram... (If Indigo was a 64bit-app, which isn't the case xD)
I forgot, how much it is, with 32bit-apps but it's still reasonably higher than the 2-2,5MB Ram limit than on 32-bit windows...
How much Ram do you have?
Post by BbB » Tue Dec 11, 2007 10:42 am
Got 4gig of RAM and I've rendered much heavier scenes than that in the past, including with Indigo 32bits. Unless of course 1.0.4 uses a huge amount or ram compared to 1.0.3
Post by Kram1032 » Tue Dec 11, 2007 11:16 am
strange...
Post by BbB » Tue Dec 11, 2007 11:40 am
Strange indeed
0charly0
Post by 0charly0 » Wed Dec 12, 2007 12:03 am
the mesh seems clean. It 's robust, I like it!!
nice textures, nice materials, great idea.... great job 8)
Post by BbB » Wed Dec 12, 2007 12:12 am
Thanks Charly. I'm cooking the aforementioned new angle right now. It's taking ages to clear. Will post it late tonight.
Post by BbB » Wed Dec 12, 2007 10:44 am
A new angle. 26 hours on my Quad (2400x1800 pixels) using the latest Win 64bit version of Indigo. I don't know which of the two angles I prefer. The setting is better in the first, though the models are clearer in this one. The DOF is way to shallow, though, which drowns the details...
