caustics behind dielectric??
7 posts • Page 1 of 1
Slobodan
Post by Slobodan » Sat Dec 01, 2007 11:49 am
I'm reading that MLT based renderers have issue with caustics behind dielectrics. What's the deal with that?? Can Indigo do those??
Thanks,
Slobodan
Post by Kram1032 » Sat Dec 01, 2007 11:54 am
yes it can, since some time, now.
There already was a HUGE test-thread, which showed the problem and went on, when the problem was solved and much more recently, there was a test, again :)
You just need to make sure, that your Max_num_consec_rejections (a render-setting, found in the inifile and in theory also in your exporter's gui) is at at least 1000 - then, you should see caustics through transparent stuff :)
Post by CTZn » Sat Dec 01, 2007 5:48 pm
Or you don't use bidir and wait some more...
Slobodan
Post by Slobodan » Sun Dec 02, 2007 4:55 pm
Thanks for reply guys..
I was at NextLimit forum and some people bitched about not being able to see caustics behind transperent stuff. Someone said that is common for MLT renderers. I was sure though that indigo can do that.. :)
Post by Kram1032 » Mon Dec 03, 2007 3:54 am
as I said, it can, but not since too long :)
CoolColJ
Post by CoolColJ » Wed Dec 05, 2007 12:18 pm
as long as you have bidrectional on and MLT with MNCR at least 1000 then you will see them given enough rendering time
Maxwell is just Path tracing, no MLT there, so you will never see caustics behind glass ever :)
need MLT for that
psor
Post by psor » Wed Dec 05, 2007 12:28 pm
" ... need MLT for that"
That's the point! :D :D ;)
take care
psor
"The sleeper must awaken"
Users browsing this forum: Google [Bot] and 41 guests
