by Kram1032 » Sat Dec 01, 2007 8:56 pm
for dirt => for blurrier lines and imperfections on the lens^^ (and I think, the lensshape itself also gets controlled by this
Just try to set a very high f-stop
Anthony
by Anthony » Sun Dec 02, 2007 8:42 am
High F-Stop gets a bigger blur, but I am not getting big streaks coming out the side. Is it cause Im using a blackbody emitter or maybe I just need to do more experiments
I wont bother witht he obstacle map then
by Kram1032 » Mon Dec 03, 2007 3:51 am
hi f-stop should make things sharper. But it also should give more bloom.
those "big streaks" aren't too realistic in most cases
Did anyone yet try to film the sun?
by CTZn » Mon Dec 03, 2007 4:29 am
Yes, first thing I did. Actually my diffraction map was unadapted and that was not pretty; the square shape of the map was visible. Of course now I have a better idea on how diffraction map should look
Basically shoting the sun works good.
by Kram1032 » Mon Dec 03, 2007 4:32 am
great
Maybe, I still have my amethyst scene, somewhere... Would be great to redo it
(maybe even in combination with the atmosphere... The light comes much smoother, then, so there should be a visible difference... And I think, I used full diffuse gold (exponent 0 with au.nk) as a mat and it was a not-energy-loss-compensated version, so, it might also look a lot brighter....)
by Whaat » Tue Dec 04, 2007 4:00 am
OnoSendai wrote:* added aperture_diffraction toggle in infile.
In case anyone was wondering, this can be over-ridden by adding
<aperture_diffraction>false</aperture_diffraction>
in the render settings element. I don't think this has been explicitly mentioned anywhere.
Nice work, Ono! I was a bit confused about obstacle maps at first. Maybe you could post the obstacle map that you used to produce the second glare pattern. 'diffraction_test.igs' does not produce the same glare pattern that you have shown in your first post. I suppose this is due to the lack of obstacle map.
by OnoSendai » Tue Dec 04, 2007 4:04 am
Well this is the combination of aperture + obstacle.
It's the regular nature of the obstacle grid that gives the distinctive glare pattern.
- indigo_aperture.png (78.47 KiB) Viewed 9575 times
by Kram1032 » Tue Dec 04, 2007 7:17 am
if you have a fully white picture, will Indigo interpret this as a perfectly squared aperture at maximum size?
Kram1032 on Wed Dec 05, 2007 11:21 am, edited 1 time in total.
by CTZn » Wed Dec 05, 2007 10:56 am
Fixed, I think. 1.0.4 was running in 1.0.2 folder, I believe that's because I declared msvc dll's from 1.0.2 folder in system path.
I keep having an error, "key 'aperture_diffraction' is not in the map". I've set it to circular, and neither am I using an obstacle map.
Maybe that helps:
Thanks
CTZn on Wed Dec 05, 2007 11:45 am, edited 2 times in total.
CoolColJ
by CoolColJ » Wed Dec 05, 2007 11:38 am
a bit late to the party - but nixe!
maybe time to dust the cobwebs off my Indigo directory and fire her up
psor
by psor » Wed Dec 05, 2007 11:41 am
"I keep having an error, "key 'aperture_diffraction' is not in the map". I've set it to circular, and neither am I using an obstacle map."
Because you are rendering with the .ini of v1.0.2! That's the point.
take care
psor
"The sleeper must awaken"
by CTZn » Wed Dec 05, 2007 11:46 am
CoolColJ
by CoolColJ » Wed Dec 05, 2007 12:22 pm
only problem with having bloom as part of the render process, is that your stuck with it....
or is it a tonemapping thing like the Camera Responce?
by CTZn » Wed Dec 05, 2007 12:34 pm
Sorry that's me again, but upon first test I had the impression that it was pretty much sensible to burn value, easy to set isn't it ? But that need further investigating.
