Indigo v1.0.2
right then givers
now I have been trying to raise these conical dust lines and I cant seem to get them to show
in this doodle (which I have downsized here - hence the jaggies) I expected to create cones as I sketched in here in white for each light...
there are obviously IES cones made intersecting on the orange wall but no dust effect in the atmosphere
so I ask again if this is possible or am I just not doing this well - incorrect settings/ situation
- IES test.jpg (22.15 KiB) Viewed 5927 times
Ah sorry I miss-read what you said. I would guess you just need to crank the scattering up a notch or three until they start to show up.
Here's an example known working dusty atmosphere material to check yours against in case there is actually something mis-configured in the mat (expects realistic scene scale):
Hope that helps
<medium>
<name>Atmosphere</name>
<precedence>2</precedence>
<basic>
<ior>1</ior>
<rgb>
<rgb>0 0 0</rgb>
<gamma>2.2</gamma>
</rgb>
<subsurface_scattering>
<uniform>
<value>0.05</value>
</uniform>
<phase_function>
<uniform/>
</phase_function>
</subsurface_scattering>
</basic>
</medium>
<material>
<specular>
<internal_medium_name>Atmosphere</internal_medium_name>
</specular>
</material>
yay found time this evening..
and got it functioning
partly my script fault
made the lamp meshes a little bigger too..
for posterity this its an sss value of 0.01 which is a little strong I think
0.0075 would be better
the obvious thing is I think that despite the uniformly smoky atmosphere the light follows the ies distribution so there is no scattering for the first 300mm or so - at least with this pfofile -which is somewhat wrong I think
I wonder too about having no real way to control the light output other than making somewhat crude adjustments with with camera exposure etc...
anyway thanks for the assistance
- im1195972806.png (449.73 KiB) Viewed 5771 times
