i get this error when exporting in 3dsmax 2008 :
SceneLoaderExcep: Found unexpected element 'response_function_path' in
element 'camera'. (Around line 28, column 13)
whats wrong here ?
error in maxigo 1.03.5 and Max 2008, windows xp pro
vortenbrol
did you use maxigo/indigo 0.9 before? is your indigo instalation path on indigo setup tab in maxigo set to indigo 1.0?
i had at the first try something similar with ies lights (found unexpected 'ies profile' in element 'meshlight') but then i realised i didn'y change path in maxigo to indigo 1.0 and files are exported to old indigo 0.9
Re: error in maxigo 1.03.5 and Max 2008, windows xp pro
Yep, sth is right. Wrong Indigo version. Get the 1.0.3 from here:vortenbrol wrote:i get this error when exporting in 3dsmax 2008 :
whats wrong here ?
http://www.indigorenderer.com/joomla/fo ... php?t=2977
vortenbrol
