indigo for 3d max 9 32bit(indigo gira su 3d max9 a 32bit)
10 posts • Page 1 of 1
filippo
Post by filippo » Fri Oct 20, 2006 8:09 am
indigo run on 3d max9 32 bit?
you excuse my English
indigo gira su 3d max 9 a 32 bit?
u3dreal
Post by u3dreal » Sat Oct 21, 2006 7:34 am
Sorry haven't updated and i probably never will... :D
but is should .. i think ..
cheers
u3dreal ;)
filippo
on 3d studi max 9 32 bit indigo it's ok
Post by filippo » Sat Oct 21, 2006 8:15 am
indigo gira su 3d max 9 32 bit..
cioa grazie
Adam Guzowski
Post by Adam Guzowski » Wed Nov 15, 2006 12:18 pm
yes,
I got 3dsmax9 and indigo work well ;)
u3dreal
Post by u3dreal » Wed Nov 15, 2006 12:56 pm
Adam Guzowski wrote:yes,
You mean my exporter works well ??
cheers
u3dreal ;)
3DSMax/Blender -> Indigo website:http://r3ndr.com
My Indigo Gallery !
Adam Guzowski
Post by Adam Guzowski » Wed Nov 15, 2006 1:21 pm
yes!
work very well.
Im using 3dsmax9 64bit version and XP 64bit (lots of RAM for architectural visualisation)... soon I share some of my works made in indigo with a great communication by Your exporter.
Superb work mate
thanks
filippo
yes!!
Post by filippo » Wed Nov 15, 2006 8:13 pm
yes, u3dreal, your exprter run on 3d studio max 9 32 bit!!!It work very well.
I believe that it work better on 3d studio max 9...
it excuses my English
filippo
si, il tuo exporter lavora bene su 3d studiomax 9 32 bit, forse anche meglio di prima.
ciao
u3dreal
Post by u3dreal » Wed Nov 15, 2006 11:54 pm
Adam Guzowski wrote:yes!
work very well.
Superb work mate
thanks
Thanks
good to hear it also works on 64bit version... some had problems..
did you use any other install or just like afecelis showed in his tutorial ?
cheers
u3dreal ;)
Adam Guzowski
Post by Adam Guzowski » Thu Nov 16, 2006 12:22 am
I try to use Indigo renderer since 0.4 release but I am a very busy man.Architecture can be very time-consuming and never had enough time to play with installation process and writing XML files for my scenes.
Since I found this "afacelis" tutorials I start to play with indigo once again.
So far I didnt found any serious bugs or crashes using Your tool.
u3dreal If You need a pure dualCPU 64bit machine for some tests write a PM.
u3dreal
Post by u3dreal » Thu Nov 16, 2006 11:55 am
Adam Guzowski wrote:I try to use Indigo renderer since 0.4 release but I am a very busy man.Architecture can be very time-consuming and never had enough time to play with installation process and writing XML files for my scenes.
Okie will do if so...
cheers
u3dreal ;)
