CoreDuo Chip
14 posts • Page 1 of 1
Kosmokrator
CoreDuo Chip
Post by Kosmokrator » Mon Nov 12, 2007 2:25 am
A Simple Image with indigo 1.0.1
hope u like it....
DuoCore copy.jpg (657.46 KiB) Viewed 16477 times
Post by OnoSendai » Mon Nov 12, 2007 2:44 am
Nice, excellent brushed metal material!
Post by Kram1032 » Mon Nov 12, 2007 2:50 am
indeed! that's great!
ciccio
Post by ciccio » Mon Nov 12, 2007 3:43 am
great! great!
kadajawi
Post by kadajawi » Mon Nov 12, 2007 3:55 am
The brushed metal looks nice, but are you shure it is brushed in reality? That should make no sense whatsoever, CPUs need to be as flat as possible (that's why some people lap their CPUs to a mirror finish) in order to give the best possible contact to the cooler. Also you may do some phong shading in the corners. Otherwise nice work :) The PCB looks amazing.
Post by CTZn » Mon Nov 12, 2007 5:13 am
Use png for bump instead of jpg, compression really kicks it off. Nice brushed effect, even if it is not how they are conceved ;)
alex
Post by alex » Mon Nov 12, 2007 5:19 am
Nice, but in definitly lacks smoothing (look at the lower right corner of the chip) :D :wink:
Kosmokrator
Post by Kosmokrator » Mon Nov 12, 2007 5:42 am
thnx for the C&C i know about the smooth alex...just i forgot to fix this :oops:
kadajawi:cpus like this have similar "bump" like this i know this i have see many of this...may is a little strong but there is!!!
thnx again !
kadajawi
Post by kadajawi » Mon Nov 12, 2007 6:06 am
Oh, sorry. You're right:
http://techreport.com/r.x/e6300-vs-sff/cpus2.jpg
The material looks a bit different and your bumps are too strong I think. Maybe smaller too? Seem to be very fine scratches...
Post by Kram1032 » Mon Nov 12, 2007 6:23 am
If you scale that cpu down to have similar size as your reference photo, I bet, the scratches will either fit or even be smaller :)
alex
Post by alex » Mon Nov 12, 2007 8:23 am
BTW, the green part of the CPU could be a bit clearer, and use SSS ;)
zsouthboy
Post by zsouthboy » Mon Nov 12, 2007 8:40 am
Great!
Lower the bump, add some slight bump on the writing, and render a version so we can see the 700 BGA points on the back :D
Kosmokrator
Post by Kosmokrator » Wed Nov 14, 2007 7:34 am
more to come....zsouthboy!!
thnx for C & C!!!
i think its 775 pins in other side...too boring to count them but...its nessecery!! :wink:
filippo
Post by filippo » Sat Nov 17, 2007 11:29 pm
GREAT!!!
filippo
Users browsing this forum: No registered users and 148 guests
