Make sure to use single faced planes for exit portals and that they are pointing or facing inward of your interior.
Blendigo for v1.0
- joegiampaoli
If you are using this thread's Blendigo exporter, select your exit portal and in the materials drop down menu of the exporter you should find a material called (guess what?), exit portal
Using the last blendigo version to export scenes for indigo v1.0.2 I get this error:
Modifying the line 1725 of blendigo from
to
solves the problem.
Indigo Renderer v1.0.2, Windows 32-bit Release build.
SSE present.
SSE2 present.
SSE3 present.
Using 4 thread(s).
Scene file path: 'default.igs'
Using working directory path ''.
Loading Scene 'default.igs'...
IndigoDriverExcep: SceneLoaderExcep: invalid boolean value
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: invalid boolean valueCode: Select all
file.write("\t\t<cache_trees>%s</cache_trees>\n" %(CacheTree.val)) #BFCode: Select all
file.write("\t\t<cache_trees>%s</cache_trees>\n" %(IndigoBoolean(CacheTree.val))) #BFI know the problem and solved it already. I just forgot to upload new versionGNUdo wrote:Using the last blendigo version to export scenes for indigo v1.0.2 I get this error:Modifying the line 1725 of blendigo fromCode: Select all
Indigo Renderer v1.0.2, Windows 32-bit Release build. SSE present. SSE2 present. SSE3 present. Using 4 thread(s). Scene file path: 'default.igs' Using working directory path ''. Loading Scene 'default.igs'... IndigoDriverExcep: SceneLoaderExcep: invalid boolean value Fatal Error: IndigoDriverExcep: SceneLoaderExcep: invalid boolean valuetoCode: Select all
file.write("\t\t<cache_trees>%s</cache_trees>\n" %(CacheTree.val)) #BFsolves the problem.Code: Select all
- joegiampaoli
- joegiampaoli
- joegiampaoli
- joegiampaoli
I've updated it now. I hope it work properly now
- joegiampaoli
